Old 02-20-2008, 06:46 PM   #1
mazdaguy20 is on a distinguished road
engine compression test specs?
my compression was 125psi on the back two cylinders and 115psi in the front does that mean i should junk it or what the reason i checked is because its blowing blue but only when i start it up and then drive for a lil bit and its gone can someone please answer some question i looked all over the internet for specs but there is nonthying that would be greatly apreciated thank you
mazdaguy20 is offline   Reply With Quote
Old 02-20-2008, 07:24 PM   #2
z07
z07's Avatar
Pull the plugs and add one table spoon full of STP or some thick oil like 20w-50 to each cylinder via the spark plug hole. Then re-test the compression. If the values remain the same you have top end IE valve/valve seat issues. If the values rise then you have worn rings/cylinder walls.
A NAPA machine shop (and others of course) should be able to rework the head for about $250ish.
L29 big block specs stumpuller454 GMC Truck Forum 2 03-08-2008 04:42 PM
99 Chev Silverado-Low compression rockitman Chevy Truck Forum 10 12-04-2007 08:09 AM
Maximum Specs SuperBen Ford Truck Forum 1 06-25-2007 05:23 PM
can you hear bad compression ? xfrank12 Dodge Truck Forum 4 02-17-2007 11:08 AM
Engine Identified! Anyone know specs? klink70 Chevy Truck Forum 1 01-30-2006 10:07 PM
