| Drive shaft or differential ??? Hello! I justed got my truck last week and I have a lot of nice plans for it |
| a loss? what do you mean? you have to press the gas pedal down more or something?
| I could feel the gear hitting together when I start. |
| you can check this out 1Inspect Motor Mount Loose or broken motor mount. 2Inspect Transmission Mount Loose or broken transmission mount. 3Inspect U-Joint Retainer Missing or loose u-joint retainer. 4Inspect U-Joint Loose, worn or damaged u-joint. 5Inspect Driveshaft Center Support Loose, worn or damaged driveshaft (center support) carrier bearing. 6Inspect Ball Joint - Lower Worn or damaged lower ball joints 7Inspect Ball Joint - Upper Worn or damaged upper ball joints. 9Inspect CV Halfshaft Dry,Worn or damaged cv half-shaft 10Inspect Radius Arm Bushing Worn or damaged radius arm bushing. 11Inspect Radius Control Arm Bushing Worn or damaged radius control arm bushing. 13Inspect Driveshaft Damaged, loose, or improperly balanced driveshaft. 15Inspect Muffler Restricted, loose or burned out muffler. 17Inspect Strut Mount-Suspension Worn or broken strut mounts 18Inspect Strut Rod Bushing Broken or damaged strut rod bushing 19Inspect Tie Rod End Loose, worn or incorrectly adjusted tie rod end(s). 20Inspect Wheel Bearing - Front Worn or improperly lubricated wheel bearing. 21Inspect Wheel Bearing - Rear Worn or improperly lubricated wheel bearing.
| anything else chevy?? you forgot 8, 12, 14, and 16. i would start with the u joints. |
| LOL bradrhale trying to cover some of the bases LOL. but a good start to where to look
| Thanks guys I will keep you informed. |
| Senior Member Join Date: May 2008 Location: North Vancouver, BC. Canada
| 03Chevy, are you sure your not a closet Mazda owner
__________________ Little Blue: 1990 Mazda B2200, Little Red: 1989 Mazda B2200, 1991 B2200 Cab Plus, 1989 Black SE5, basket case |
| Full Member Join Date: May 2008 Location: South Carolina (upstate)
| Still don't get what you mean... Is there a noise? If so, can you describe the sound, and maybe where it comes from? Is there any vibration that you can feel? At what speed does the vibration seem the worst? On an older Dodge (B150) van that I had, the torsional vibration damper (harmonic balancer) had been buggered by some goof changing the transmission. He used it as a place to jack/lever. Found that after taking the driveshaft off and having its balance checked at a good truck repair shop. Did you purchase any repair books? I found that FleaBay can be a good source to pick up a service/repair manual, fairly cheaply. |
| Its hard to explain. When I press on the gas to take off I could feel that there is a loose. It feels like there is a loose in the gears of the differential but I hope it's not that. I will check my u-joints first. I'll try to find what it is and then tell you. Thanks |
| HELP!! I need to find the right drive shaft?? | Chevy_Finatic79 | Chevy Truck Forum | 8 | 05-21-2008 02:12 PM |
| Drive Shaft ? | chuckphillips | Chevy Truck Forum | 1 | 03-26-2008 06:54 AM |
| drive shaft | pbouffard | Chevy Truck Forum | 2 | 07-21-2007 10:06 PM |
| GMC drive shaft | Tazman6789 | General Truck Forum | 1 | 11-05-2004 05:29 PM |
