Old 06-05-2008, 08:37 PM   #11
Fordin Mazda's Avatar
Fordin Mazda will become famous soon enough
On my truck, the switch is buggered and it blows fuses on both my signals & tail lights. If I smack the switch, it stops grounding out for the signals. But my tail lights are done. I have to pull my wheel to replace the switch, will be doing that tomorrow or Saturday.
My Mazda will probably out live my Ford. Both are over 200,000 miles.
Never look at gift horse directly in the mouth. They chew with their mouth open....
Fordin Mazda is offline   Reply With Quote
Old 06-06-2008, 05:10 AM   #12
aretevince is on a distinguished road
On mind its only the tail light that don't work and also my dash board lights but its probably because its on the same fuse. What do you mean when you say that you have to take off the wheel to change the switch. Do you mean the steering wheel??
aretevince is offline   Reply With Quote
Old 06-06-2008, 11:30 PM   #13
If the B4000 switches are the same as the B2200, and attached to the steering column then yes, you have to remove the steering wheel, to replace the switch, because the entire piece, has to be replaced, you can't just replace the switch.
I pulled my wheel today, and replaced the switch, I have turn signals, and high beams again, but my dash lights & tail lights are still blowing fuses. So now I have to go and find the break in the harness.... OH GOODY...
Old 06-08-2008, 01:15 AM   #14
mmmm it gets better & better... Now I have developed the same issue as you. Hit the brakes & the left turn signal (dash light) comes on, and left signal doens't work. Front & Rear signals are steady on, no flash. I have found LOTS of breaks and frays and etc. etc. I have to replace the entire tail light harness, now I have to wait for Pick-a-part to get some more donor trucks, they have 4 as of current, and they all have been picked clean.
I also ran over a stick today, that put a 1/2" hole in my tire. Damm chunk of wood, never would have guessed a chunk of wood could pierce a tire. I'll have to see if I can find the chunk and take a picture.
Old 06-09-2008, 05:40 AM   #15
oh no that sucks fordin mazda. I took off my switch this weekend and found that there was a whole lot of **** that was built up in there so took it off and cleaned everything and there was also a wire barely connected so I reconnected. I don't know if it was the real problem but my lights are not blowing fuses anymore. One problem solved but I still have the problem with my flasher lights that come on when I press the brake. I'll check that when I have two minutes this week but I think that it is probably the plug under my truck that is rusted out or something like that but I hope I won't have to go through the whole wire harness like you did. I'll keep you informed.
Old 06-09-2008, 12:58 PM   #16
from another Mazda Truck (dedicated to Mazda only) forum I am on...
Originally Posted by toddluck
could be your brake light switch on the pedal...unplug it and see what happens
I haven't done that yet. I'll do that today, and let you know the result.
Old 06-09-2008, 03:01 PM   #17
I found my problem youppi!!! It was the damd trailer harness. I cut off all the wires that related my conversion box to my lights and everything came back ok. So I will have to buy another conversion box and replug them. I'm happy it was just that. Keep me informed of your problem. Thanks for everything.
Old 06-11-2008, 12:30 AM   #18
Found my problem:
The exhaust system was mickey moused (like other stuff on the truck) the tail pipe is too short, the muffler is off who knows what... Anyways, the tail pipe was up at the bottom of the box, and melted all the wires where they cross the frame causing the short. from the state the area melted was, I surprised I had any lights...
Now I have to fix my exhaust as well....
Old 10-06-2008, 07:12 PM   #19
chankee is on a distinguished road
Check the bulbs, fuses and especially your wirings. Try to look at the lights switches too. Some mazda oem parts have problems so don't worry too much about that.
chankee is offline   Reply With Quote
2000 Chevy C3500 Dually turn sig/brake light MiamiHost Chevy Truck Forum 2 02-12-2008 05:58 PM
Turn signal problem please help lemoncoke GMC Truck Forum 5 02-07-2008 06:02 PM
Left Turn Signal/Brake Light issue.. itzmarko1 Chevy Truck Forum 7 01-28-2008 09:52 AM
Brake light problem gejandsons GMC Truck Forum 2 07-11-2007 03:37 PM
brake light problem ramdodge Dodge Truck Forum 5 09-18-2006 07:05 PM
