Mazda Truck Forum - Mazda trucks, etc |
#1 (permalink) |
EGR Flow Insufficient
I have a 96 B3000. Has a slight rough idle and the code reader gave me P0401 which is Egr Flow Insufficient. I replaced that and cleared the code. Slight idle still there and code P0401 is back. Plugs and plug wires are recent. Fuel filter maybe? What should i check next? Thanks.
#4 (permalink) |
you will want to clean it with throttle body cleaner.You can usually clean the old ones.spray it and keep working the valve so it moves in and returns by itself.Spay the ports when the truck is running. I use a whole can on that
#5 (permalink) |
The best way to do it is too just pull the manifold off and clean the passages. the carbon is very hard, and would like cause internal engine damage if the chunks were allowed to travel through the motor..
Joe 89 K2500 Chevy, Wee-Oh-five 285K miles, completly rebuilt needs a motor, bad 1962 IHC Scout All Wheel Drive (Scout speak for locking axles) 152 ci, dana everything else |
| High flow fillneck | leolkfrm | GMC Truck Forum | 3 | 03-06-2008 06:04 PM |
| Air Flow | stumpuller454 | Chevy Truck Forum | 4 | 02-16-2008 06:11 PM |
| mass air flow sensors | smylesM04 | GMC Truck Forum | 0 | 12-29-2007 02:11 PM |
| Max Air flow Sensor | cajunwoodrick | GMC Truck Forum | 8 | 05-03-2007 03:30 PM |
| the loudest high flow cat out there????? | cambo | Chevy Truck Forum | 4 | 03-01-2005 08:34 AM |
