| Full Member Join Date: Apr 2008 Location: fairfield,ca
| where the **** is my tranny dip stick? so my tranny is leaking alittle fluid and i wanted to check the level and add alittle more if i need to but i cant find the ******** dip stick anywhere i know this is a pretty dumb question but does anyone have an 89 b2600i and know where the ******** dip stick is? |
| Is it a manual shift or automatic? If it is a manual, there is NO dip stick, there is a screw on the left(drivers) side of the tranny. Pull it out and stick your finger in, if the level of fluid is level with the hole, then the level is fine, if it is low, then the way to fill it is the same to check it, kind of a pain, but there it is. If it an automatic, the dip stick is still on the drivers side, but tucked down close to the motor. Hard to see and kind of hard to get too, but it is there. Hope this helps.
| thanks its a manual i am gonna go check it right now |
| 1991 1500 Brake Lights Stick On? | harleypapa | GMC Truck Forum | 8 | 11-09-2007 07:02 AM |
| engine throwing oil out dip stick | evenlope | Ford Truck Forum | 5 | 08-01-2007 11:08 AM |
| Stick on wheel weights | KMW | General Truck Forum | 4 | 06-27-2007 07:53 PM |
| 1/2 ton vs. 3/4 tranny | cwenisch | Chevy Truck Forum | 2 | 05-24-2007 03:53 PM |
| v-6 tranny? | celicagt4 | Toyota Truck Forum | 1 | 01-06-2005 01:10 PM |
