| Full Member Join Date: Feb 2007
| Oil Additive Anyone ever use Marvel Mystery Oil? I'm considering using it for a hundred miles plus/minus just before an oil change. Any good or bad experiences using it? |
| I don't know about MMO but I will share my own expirience with SeaFoam. I took the intake off to reseal the intake to China-wall. While it was off I saw it looked nasty inside. So I took some SeaFoam and put it into a spray bottle and outside, holding my breath, I sprayed down the inside of the intake. I let it sit while I removed the gasket from the block and heads. I went outside with a detail brush and the spray bottle to take care of any trouble spots but was happy to see that there were none. All the goo had dripped into the pizza box+kitty litter I had under the suspended intake manifold. There are many people who add SeaFoam to the oil before a change 1/2 in the tank and 1/2 in the crank case. |
| ditto to sea foam.. That is some great stuff.
| after seeing the inside of my intake, i think i might buy some soon.
| I use Seafoam only in my gas tank but for my oil I use STP. |
| Junior Member Join Date: Oct 2008 Location: Texas Hill Country
| I use a pint of Marvel Mystery Oil at each oil change. It keeps varnish down in the engine and enhances the lubricity of the oil. We used it in all of our racing engines. I also use a pint of STP at each oil change. HTH
__________________ ----------------------------- "No matter where you go, there you are.", Buckaroo Bonzai |
| Senior Member Join Date: Aug 2008 Location: Kentucky
| i was weary of additives but after reading here just might have to try..want my truck to last a long time and it is almost time for oil change
__________________ looks are cosmetic.....its whats under the hood that counts ![]() ![]() |
| I just added Seafoam to the extra SUV we have I poured the stuff down the vacuum booster hose it smoked like if I was smoking some meat but it sure made the gas response feel better I love the stuff I wish I could drink it to run better. |
| Fuel Line Additive ?????? What Is It | ERIC777 | General Truck Forum | 0 | 07-13-2007 12:44 PM |
| Transmission was slipping. LUCAS ADDITIVE | gmctrucks | Off-Topic | 6 | 12-15-2006 09:56 AM |
| Air Filter Test, Oil Additive Test & More | Chevy808 | Off-Topic | 0 | 12-03-2006 09:31 AM |
| acetone as a fuel additive | mochester | General Truck Forum | 11 | 06-29-2006 11:32 PM |
