| | #11 |
| i think its a manual bythe way he says... when he shifts |
| | #12 |
| Full Member Join Date: Nov 2008 Location: Saskatoon,SK
| well i went out and sprayed WD on the cable and while i was out there i started it and played with the throttle and when i turned the throttle manually about a 1/16th of a turn the motor would rev right out. |
| | #13 |
| yup sorry didn't specify its a manual 5 speed |
| | #14 |
| yeah i would say you have a bad injector or throttle position sensor.... i would try the tps before doin the injectors cause they can cuase more problems if not done right |
| | #15 |
| i had a fuel injected mustang and to set the tps you used an ohm meter and set it that way are these mazdas the same? |
| | #16 |
| no i dont think so.. i have never heard of that... im pretty sure there calibrated from the factory with in a set parameter.... i know you can use an ohm meter to check it but not to install it... i would do a lttle digging on the specs of your tps and check your out with an ohm meter... i think it like 0.5 volts and it should climb with the throttle position as you throttle up... al it is is a resister that adds more or less resistance as you go up... if yours goes up from 0.5 then jumps up dramically as soon as you hit that 1/16 mark then that is your problem... |
| | #17 |
| check your IAC if it has one, it may be stuck open.
| | #18 |
| I was just testing some of you I knew it was manuel as well. LOL |
| | #19 |
| lol... sure you where.... |
| | #20 |
| so i seafoamed through the booster line smoked like crazy, idles nicer but didnt solve my problem.Im gonna take a guess that its the tps if any of you have the haynes can you let me know the exact specs to set it i looked at our local shop and they dont have one for my truck. |
| 1986 turbo 400 shifts hard | chevy86 | Chevy Truck Forum | 3 | 05-30-2009 10:03 AM |
| 96 305 RPM's ramp up | Buroaktree | GMC Truck Forum | 10 | 08-22-2008 09:40 AM |
| tranny shifts funny when raining | brokenbudget | GMC Truck Forum | 4 | 11-24-2007 05:53 PM |
| Tranmission mis shifts | chazzvette | Chevy Truck Forum | 1 | 05-10-2006 10:07 AM |
| Off-road vehicle: DJ Z-Trip shifts gears, follows own road on first headlining tour (Boston Herald) | trucknews | Truck News (headlines) | 0 | 09-05-2005 07:30 PM |
