| Junior Member Join Date: Nov 2008
| '03 B3000 Clutch/Shifting Issue Alright, so I've been driving standard for two years on/off, and have just started driving my brother's old B3000 after recently purchasing it off of him. I've been driving it regularly for maybe a month after it's been driven minimally for almost a year, and I'm having issues with shifting. When I'm shifting up, the gears aren't sliding into place easily like they should be. Shifting out/in again I have to give it that extra bit of pull/push. It seems like it's getting worse and it's really starting to get to me. The clutch also makes this weak whine noise when I disengage it at a standstill, and it then leaves when I engage the clutch again (to neutral). Thoughts? |
| Banned Join Date: Oct 2008
| as far as it grinding a little i have had the bushing where the rod connects to the petal get egg shaped and that happen i replaced bushing and it worked fine... may be a bad slave cylinder on my chevy it has a alamite on the shaft it may need greasing |
| Full Member Join Date: Nov 2008 Location: Saskatoon,SK
| start with checking your clutch fluid level, as for the whining noise thats just your release bearing making noise prob. worn out. |
| has the clutch been replaced yet? if not how many miles are on it? and the noise you hear when the clutch is inguaged is the throw out bearing nothing really to get all worried about it's from riding the clutch a friend on mine's wife rides it all the time and i tried to tell here not to do that but some people just don;t listen.
| '98 B3000 heat/air fan/switch issue... | KlrBill | Mazda Truck Forum | 1 | 11-03-2008 06:42 PM |
| Off road + Mazda B3000 (NO 56k) | TrucksGetDirty | 4x4 trucks / off road | 51 | 10-08-2008 09:43 PM |
| 1994 chevy 1500 shifting issue | floydv | Chevy Truck Forum | 5 | 07-21-2008 07:37 AM |
| 2001 Mazda B3000 | TrucksGetDirty | Truck Classifieds | 1 | 06-21-2008 09:46 PM |
| B3000 tuneup | topkat | Mazda Truck Forum | 0 | 01-11-2008 04:36 PM |
