Old 11-29-2008, 05:32 PM   #1
driver is on a distinguished road
Transfer case info
will the transfer case off of a automatic tranny fit my 5 speed manual tranny? i have a '91 mazda b2600i and the parts are off the same year and type of truck just wanted to know if it will bolt right up????
driver is offline   Reply With Quote
Old 11-29-2008, 05:54 PM   #2
93blazer's Avatar
93blazer has a spectacular aura about93blazer has a spectacular aura about
not sure i would think it would
**IF YOU AIN'T FIRST YOUR LAST**
SHAKE AND BAKE !!!!!!!!
93blazer is offline   Reply With Quote
Old 11-29-2008, 06:02 PM   #3
93blazer's Avatar
do you know the model of the automatic and the model of the 5 speed
Old 11-29-2008, 07:36 PM   #4
Banned
merlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to behold
If both transmissions came from the factory setup for 4WD they will interchange. If one is 2WD and one 4WD you will need to swap the output shafts.
merlin5577 is offline   Reply With Quote
Old 11-30-2008, 10:11 AM   #5
ya both are original factory 4x4, I'm only worried because my gear shifter for my tranny goes through my t -case and on a auto i don't know how its setup. another question to do valve guides and seals can i do them with the head still on the block or do i have to pull my head?
Old 11-30-2008, 11:12 AM   #6
Banned
If they are both factory 4Wd the will interchange easily.
The best way to do valve guides and seals is to remove the head. If you already have it apart I would suggest replacing the valves, springs, and retainers (keepers) at the same time.
Old 12-01-2008, 07:39 PM   #7
but what I'm looking for is the quickest way to do the seals, if its possible to do the seals and guides with the head on the block I'd rather do it that way(less parts to deal with on the garage floor)
Old 12-01-2008, 09:29 PM   #8
Banned
honestly it is quicker to do it withthe heads off the truck... but then you have to replace the head gasket and exhuast gaskets... i have done them both ways and it was so much easier to do it withthem off the block... guides are a pain to begine with.. then add that you cant take the valve out...lol it aint fun.. i had to do it withthem on the truck before because my boss was a cheap ***... didnt want to spend a few bucks to save himself my labor fees..lol he wasnt happy with what i charged him for the job but to top it off i told him it would have been cheaper to do it right and he almost fired me.... good thing i was one of his crew cheifs and not his full time mechanic
Old 12-02-2008, 05:41 PM   #9
well, i guess I'll just rebuild the head that's on the parts truck I'm buying, thx for the info really helped me out.
Old 12-02-2008, 09:17 PM   #10
Banned
any time... since you have it off and will be dis assembling it may i suggest a port job... it would open up some more bottom end torque
Tags
transfer case
'01 Gmc Transfer Case GM For Life GMC Truck Forum 10 03-10-2009 02:38 PM
208 Transfer Case HIGH86TX Chevy Truck Forum 1 07-16-2007 07:06 PM
'98 Transfer case mont91 Chevy Truck Forum 3 05-22-2007 12:10 PM
Transfer Case flossy2259 Dodge Truck Forum 0 08-08-2006 05:00 PM
transfer case guidorr73 Dodge Truck Forum 2 12-12-2005 06:39 AM
