Old 12-18-2008, 08:45 AM   #1
Linda777 is on a distinguished road
Question 1998 Mazda B2500 truck makes a squeaking sound when accelerating, even in neutral
My boyfriend has a 1998 Mazda B2500 truck, it has a regular cab with a 4 cylinder engine. The past few weeks, we’ve noticed a squeaking sound when you press the gas pedal. As soon as the gas pedal is released the squeaking stops. Yesterday, he realized that it also squeaks when it's in neutral, when the gas pedal is pressed.
Linda777 is offline   Reply With Quote
Old 12-18-2008, 09:07 AM   #2
welcome to the forum
did you try lubing the pedal?
Old 12-18-2008, 09:56 AM   #3
I forgot to mention that it doesn't squeak untill the car is warmed up, after the car has been running about 15 minutes. The squeaking isn't from the gas pedal itself but thanks for your suggestion.
Old 12-18-2008, 10:00 AM   #4
maybe a bearing thinking of giving up. might also check the belt for glazing.
Old 12-18-2008, 10:13 AM   #5
Which belt and where would the belt be?
Old 12-18-2008, 10:19 AM   #6
by that comment, maybe we need a little more information. about where does this squekiness coming from?? inside the cab or in the engine compartment?? if from the front of the car, i was referring to the belts on the engine. specifically the alternator pulley.
Old 12-18-2008, 12:51 PM   #7
It's definately not in the cab, I think my boyfriend said he thought it was in the engine or drive shaft.
Old 12-18-2008, 01:18 PM   #8
Is this a manual transmission vehicle?
When was the clutch last changed?
The very first thing that came to mind was either an idler pulley, or the release (throughout) bearing in the transmission.
If the noise is heard while the vehicle is in neutral, and the vehicle is not in motion, then we can rule out the driveshaft.
Try to depress the clutch pedal to see if the noise goes away.
I am kind of leaning towards the release bearing. They typically start to squeek when they are getting tired.
Gonna have to poke around to see where this noise is coming from.
To verify an engine related squeek, you can spray a little stream of water from a squirt bottle on various parts to detect a failing part. The water will not damage or make things worse like oil will if you spray a belt, but it will make the component silent so you can isolate the problem.
Old 12-18-2008, 07:40 PM   #9
see error's Avatar
see error has a spectacular aura aboutsee error has a spectacular aura about
i agree with 75k30 through out bearing i would say its a stick because you said in neutral not park does it stop when the clutch is pushed in?
2004 gmc 1500 cc 4x4
see error is offline   Reply With Quote
Old 12-19-2008, 12:36 PM   #10
It a a manual transmission. The clutch has never been replaced and it has only 67,000 miles on it. He tested it and depressing the clutch does not make the squeak go away. He thinks it is coming from under the hood.
1999 Mazda SE B2500 smokejumper0902 Truck Classifieds 0 09-14-2008 08:41 AM
neutral safety swith dasafgmc68 GMC Truck Forum 3 07-14-2008 07:00 PM
engine bucks when accelerating swamphunter Chevy Truck Forum 4 07-07-2008 03:05 PM
97 s10 makes clunking sound when put in reverse Rory Chevy Truck Forum 2 11-06-2007 08:43 AM
