| Junior Member Join Date: Aug 2009 Location: Pleasant Garden, NC
| center support bearing tried to replace CSB in my '92 B2200 Ext.cab A/T, part bought at Advance had a bearing ID of about .93". Drive shaft mics out to need a bearing ID of about 1.1" (28mm). All of my parts researches for B2200, B2600, 2WD, 4WD, even Mitsubishi, none show any bearing ID that big. What gives? |
| Senior Member Join Date: Aug 2009 Location: Ft.liqourdale, FL.
| i know those bearings are usually press fit that could be your difference in measurement
__________________ ASHES TO ASHES, DUST TO DUST, IF IT WEREN'T FOR CHEVY'S MY TOOLS WOULD RUST |
| every swing bearing i have seen was press fit. usually had to clean off that side of the driveshaft before trying to put it on allowing it to slide on easier. could this be part of the differance?? |
| last one i did was in the winter. stuck the driveshaft in a snow bank and took a heat gun to the bearing. slide on like butter.
| center support bearing Can't see this one pressing on, won't even go over splines at shaft end. Also, 3mm size difference seems excessive to press. |
| Appears that Mazda used both 25mm and 1" on driveshaft I'm about to replace the center support bearing on my '92 B2600i. I've dug everywhere I can to find information, and best I can come up with is that some driveshafts had a 25mm shaft through the center bearing, and others had a 1" (25.4mm) shaft. Autozone and Advance seem to sell the 25mm ID bearing. I have ordered Anchor P/N 8551 Center Bearing, and the tech guy at Anchor tells me it has a 1" bearing ID. Anchor Industries |
| Most late B2200's/2600's take a 1.102" ID bearing which can be bought at Power Train Industries part # 2680-40, their phone # is (800)798-4585. Hope this helps! |
| Support those overseas | mudseeker | Off-Topic | 21 | 04-22-2009 04:18 AM |
| What would I call these, support bars? | Ninja_Lawn_Guy | GMC Truck Forum | 27 | 02-27-2009 07:47 PM |
| Chevy man gotta Dodge.. Aftermarket support? | thomasnchy | General Truck Forum | 25 | 09-26-2008 09:17 AM |
| General Zod: He doesn't need our support...he demands it! | z07 | Off-Topic | 0 | 06-26-2008 06:14 AM |
| rear torshin bar support | robw1988 | GMC Truck Forum | 8 | 12-11-2007 08:29 PM |
