| hey guys. i got a 5 speed mazda b4000 with locking hubs up fron and im trying to replace the ball joints (top and bottom) and the u joints. how do i go about taking of the rotor on this. is there some sort of snap ring or something because they do not seem to pull off. thanks alex |
| not sure but should be one of two ways. either the rotor is froze on there or the rotor is part of the hub assembly and the spindle nut must be removed in order to remove the rotor. probably the latter of the two if i was a betting man. |
| or..........there could be a screw holding the rotor to the hub if they're OEM.
| theres no screws holding it and its not froze on there. im pretty sure theres some sort of nut. im taking it apart tommorow and hoping for the best. |
| 1994 B4000 engine slants after accident | tashirosgt | Mazda Truck Forum | 5 | 12-01-2008 09:59 PM |
| ball joint help! | see error | GMC Truck Forum | 14 | 11-27-2008 06:37 PM |
| ball joint advice | duckle1 | Chevy Truck Forum | 7 | 05-19-2008 11:08 PM |
| Lower Ball Joint | rednekracer | Chevy Truck Forum | 7 | 05-07-2007 09:03 PM |
| Ball joint replacement | vettman | Chevy Truck Forum | 3 | 08-20-2005 02:29 PM |
