| need help ive got a 1990 b2200 and it wont rev over 3500 rpms an wanted to know if anybody could help me |
| Check your fuel filter , it may be starving for fuel. Also when was the last tune up.
| it has a new filter an about a week ago |
| does it have a mechanical linkage?? i have had a linkage rod get in a bind before and not let the throttle open up all the way. |
| it opens all the way i just dont no what it could be |
| it will rev over 3000 when Im stopped an out of gear but its slow when Im driving it goes to 3000 then just stops pulling |
| Sounds to me like your IAC is having an issue.
| could be a bad convertor stuck in lock up...........
| could also be a partially plugged cat.
| its a 5 speed an i took the cat off |
