Old 10-17-2009, 12:09 PM   #1
duey is on a distinguished road
02 B3000 Dual Sport fuse diagrams?
Newbe hear, I just bought my wife a 2002 Dual Sport B3000 And the idiot that had it ran into one of those post in front a some store and set off the air bag, he apparently replaced it with a ranger air bag and I don't know whether he didn't hook the horn up or if theres a fuse blown or what but I need a Diagram of where what fuse goes to what where. In the old days they used to put it on the panel of what fuse ran what but that would be too easy. We are both out of a job and I don't really want to spend the money on a book and not know if its even in it. SO, does anyone have a copy of it that I could print out, I would really appreciate it. thanks guys
duey is offline   Reply With Quote
Old 10-18-2009, 07:22 AM   #2
crabtruck's Avatar
Welcome to the forum duey.
Don't have a fuse list for you but I can add something.
If you don't have "Power Equipment" then check Fuse #35 (15A)
in the central junction box. Also may want to check horn relay
in Aux relay box#1.
If you do have the fancy equipt, not so easy, for
then it's fed through the Central Security Module.
Check fuses#35(15A) and #8(20A), and as long shot #11(7.5A).
Before you do any of that, remember horn was first one on scene
when it was crashed. Check thoroughly for connections at horn
to be good and then verify horn actually works itself.
Bumping the Dk Blue wire with 12v is a quick test of horn and ground.
Horn can be very loud, so stand back while making connections.
Old 10-18-2009, 11:01 AM   #3
I tested the horn itself and its good, I took the front off the steering wheel and the air bag wasn't hooked up, not sure if that has anything to do with the horn tho. It looks like the horn power comes through the cruise wiring but I don't get any power on anything there. I will check all the fuses and the relay u sugessted and get back with you, I appreciate the help man. Its really starting to tick me off.I have always hated auto wiring. thanks again
Old 10-18-2009, 11:12 AM   #4
Maybe this can help you or you can ask someone there for help.
Good luck! GMC
2002 Mazda B 3000 Pickup
Old 10-18-2009, 07:48 PM   #5
crabtruck's Avatar
not sure if that has anything to do with the horn . Nope
First, don't hate the wire, hate the wirer.
There should be clock springs under the wheel.
Test the horn again by supplying Ground from there
on the spring that connects to 2 horn switches and
the cruise resistor. Power does not come from cruise,
not too sure why it wants to know when you honk horn.
BTW use a 20A fused wire for grounding or any other
such jumping tests, adds a little safety.
You will NOT get power there because horn switches
are for connecting to ground.
Actual horn wire does not go through steering wheel.
There are 4 clockspring connections. Gounding the
Yel/LtGrn wire bypasses the stuff at wheel and tells
you the rest of stuff is ok (fuses,relay,horn, SecMod)
if that makes horn honk.
If it works when you ground the Blk/Wht wire,
while pushing the horn buttons, then that ground
is bad. If not then the switches are bad,
which is not likely to have both at once,
so look for breaks there.
Since we haven't established whether you have
the basic horn or "power equipt" w/ SecMod
these are just basic checks. Horn is fed by relay
if basic, otherwise horn connects to SecMod.
Use a vise on the Dk Blu wire at horn,
then look around dash to see where the
electrons are leaking out.
Old 10-19-2009, 06:24 AM   #6
I'll try and see what happens. Haven't seen any electrons, but I saw a proton run across the dash earlier, man thier fast. Does anyone have a service manual? if so, does it have a diagram in it showing the fuse panels? There has to be a diagram somewhere!. OK, thanks guys, Duey
Old 10-19-2009, 09:04 PM   #7
crabtruck's Avatar
LOL, I guess that means you read all the way to end.
That's not always true.
I don't have a manual, but I'll keep my eyes open.
Wiring Diagrams austinjones83 Chevy Truck Forum 2 04-08-2009 07:21 PM
Off road + Mazda B3000 (NO 56k) TrucksGetDirty 4x4 trucks / off road 51 10-08-2008 09:43 PM
B3000 Tailgate Liner ansehnlich1 Mazda Truck Forum 6 10-06-2008 07:23 PM
B3000 tuneup topkat Mazda Truck Forum 0 01-11-2008 04:36 PM
