| Junior Member Join Date: Oct 2009 Location: Colorado
| 4x4 low light will not come on 1996 mazda b4000 the light worked as well as 4 low when i bought it 3 months ago, now neither works. 4 high works fine. i have auto hubs and M\T. also a 3 point selector on dash 2wd, 4high, and 4 low any help or where to start |
| i would assume bad bulb. such like that is probably in the switch and near impossible to replace unless you are one of type people. |
| well i see the light come on when i start the truck up, so.......... i suppose maybe the switch on the dash board, i am just a wee bit nervous about taking apart the whole dash to get to the switch YUCK |
| Then perhaps the light is not coming on (correctly) because it's not engaging. May want to do a visual under truck for connections. Sorry I don't have more for you. |
| i think your right because i don't hear anything engage when i put it in 4 low, i do hear the module click and the drive shaft go into gear though when i put it in 4 high. i suppose i will start with the switch on the dash tomorrow, then underneath. Last edited by jsepso04; 11-01-2009 at 09:39 PM. |
| Air bag light on | 66 chevelle | Chevy Truck Forum | 4 | 10-09-2009 09:12 PM |
| SES Light On | ChevyMan65 | Chevy Truck Forum | 4 | 08-31-2009 11:18 AM |
| 02 F-150 ABS Light is on | PRICEFORD | Ford Truck Forum | 7 | 02-21-2009 04:06 AM |
| ABS light | fisher429 | Dodge Truck Forum | 1 | 09-17-2006 01:14 AM |
| Check Engine light and overdrive light on | chief | Introductions | 0 | 02-05-2006 08:12 AM |
