Results 1 to 4 of 4
Like Tree4Likes
  • 1 Post By Bruce2
  • 1 Post By gpmorgan
  • 1 Post By OldTruck
Thread: 1986 Mazda B2000
    Newbie
    Jan 2013
    1
    1986 Mazda B2000
    I just got an old B2000. It will start when it wants to and die when it wants to. There's no pattern to it. It has a carb so it can't be a fuel relay, although that's what it acts like. I changed the fuel filter, no improvement. Any ideas?
    MrMarty51 likes this.
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    probably need to catch it in the no run situation and check for fuel and fire and determine which one is causing the problem.
    Newbie
    May 2015
    1
    Just had the same issue. It usually started but would randomly die. Problem was the ignition switch. The contacts were pits would lose contact in the run position.
    MrMarty51's Avatar
    Aug 2013
    5,712
    Welcome to the forum Bruce.
    It has to be one of three things. Fuel, spark or compression, or, does the temperature gauge climb excessively high just before it shuts down ?
    93 GMC K1500 Automatic, 350V8
    91 Chevy K1500 5spd Manual, 350V8
    1959 Dodge W100 4spd manual, Poly Head 318
    1979 K20 TH400 Automatic, 400V8
  1. Mazda b2000
    By kcraig11 in forum Mazda Truck Forum
    Last Post: 04-15-2012, 01:04 AM
  2. My mazda b2000
    By vfightfighter15 in forum Mazda Truck Forum
    Last Post: 01-30-2012, 08:54 PM
  3. 87 Mazda B2000 Falied California Smog
    By JChampion in forum Mazda Truck Forum
    Last Post: 10-14-2011, 02:27 AM
  4. 87 mazda b2000 timing belt problems
    By mn82 in forum Mazda Truck Forum
    Last Post: 08-16-2010, 05:10 PM
  5. Mazda B2000 Drive Shaft Swap
    By Dav577 in forum Mazda Truck Forum
    Last Post: 08-04-2009, 11:14 AM
