| Full Member Join Date: Feb 2006
| 90 b2200 loses spark I ran fine until one day it died and then started 10 times in a 30 mile drive. It's fuel injected, Ca. model. with about 100k on it. I've replaced the distributor because I got a high resistance reading from it. The coil checks out ok. The ignitor could be at fault or could be the ecu? It will start and run at first for about 5 minutes and then die. Could there be a problem with the fuel system that tells the computer to kill the ignition? |
| No help here? |
| try your fuel filter it could be pluged, what ever it is picking up is probably settleing after it shuts off.If thats not it your fuel pump may be going out on you. Yes this site is a little slow, life can be very busy but that doesn't mean you have to leave.
| Thanks Thanks for the reply. I found out I'm still getting fuel and it will still start and run, but then die after a minute or two. Then it might start and run or not. I pull a plug and it's wet. Ground the plug and turn the engine over, no spark. Next day, same thing, it will start. I was wondering if the Ignitor is at fault. It seems to get a little hot. I switched it out with several other ones I pulled from the junkyard. They all work the same. Could they be bad too? A new one is $93. I've already replaced the crank angle sensor in the distributor with a new one I got from a new manufacture in Taiwan. Is the fuel system tied into the ignition? Low fuel pressure causes no spark? Last edited by lithopro; 02-21-2006 at 08:26 AM. Reason: Adding another question |
| Did you check your timing after you replaced the dist. How do the injectors look? How's the fuel pressure? Just some questions to get you thinking.
| Junior Member Join Date: Apr 2006
| similar experience I had an indentical problem w/ my 91 b2600i and it ended up being the ecm. shipped the ecm to a place in flordia and for $185 or so they fixed it and shipped it back in a few days. |
| Thanks I thought that might be it too. I know an ECM from another truck in the junkyard that might be good. The man wants 60 for it. It might do the trick, it might not. With the gas going 3.07 here in Oregon, it might work. Do you have the contact info for the place you got yours fixed? |
| E3 spark plugs | gmtech | Chevy Truck Forum | 5 | 07-03-2008 06:49 AM |
| PHOTO: TRUCK MEETS TRAIN, TRUCK LOSES (Rhea County Online) | trucknews | Truck News (headlines) | 0 | 06-22-2005 11:30 AM |
| KSL News: Semi-Truck Loses Trailers (KSL-TV News) | trucknews | Truck News (headlines) | 0 | 06-06-2005 09:30 AM |
| Mail Truck Loses Load In East Baltimore (The WBAL Channel) | trucknews | Truck News (headlines) | 1 | 05-13-2005 07:30 PM |
| Beer Truck Loses Load, Creates Traffic Nightmare (KPRC Click2Houston.com via Yahoo! News) | trucknews | Truck News (headlines) | 0 | 04-22-2005 07:30 PM |
