| Junior Member Join Date: Jun 2006
| Vapor Lock??? My 97’ Mazda B-4000 has failed on me twice in the last two weeks, a friend was with me the first time and said that it was vapor lock when it started acting like it was running out of gas on a full tank. He showed me how to bleed off the air from what looks like a tire valve on the left side of the engine so I knew what to do the second time it happened. Is this what it is? Can it be prevented? What causes it? Thanks for the help. |
| where exactly is that valve? the only ones i can think of are the ones for the AC.
| If you are facing the engine it is on the left side about halfway down the block, here is a picture, it is circled and has a blue cap and then a closer picture of the valve stem (I dont know what else to call it). |
| never seen anything like that before, sorry.
| Thats where the technician hooks up a gauge to pressure test the fuel system.
