Old 10-12-2007, 09:38 AM   #1 (permalink)
Ichiro is on a distinguished road
1995 Pickup Runs Bad and Bogs Down
Thanks in advance for any help.
I have a 1995 Pickup (manual) that bogs down when the gas is pushed to the floor. I changed the EGR valve and the truck still runs exactly as it did.
This vehicle loses power going uphill and when you try to give it gas, it will bog big time. Also if I'm in neutral and simply push the gas to the floor the engine will rev and bog rev and bog rev and bog.
Any ideas?
Ichiro is offline   Reply With Quote
Old 10-14-2007, 07:10 AM   #2 (permalink)
strokin350's Avatar
strokin350 is on a distinguished road
have you checked the timing chain? my old nissan that i had was doin pretty much the same thing. the timing chain tensioners wear out. my chain ended up in my oil pan cuz i was too cheap to fix it.
strokin350 is offline   Reply With Quote
Old 10-14-2007, 11:31 AM   #3 (permalink)
scottie's Avatar
keep it simple... check for restrictions in the airflow (filter, chipmunk nest...)
Old 10-14-2007, 09:58 PM   #4 (permalink)
1bj
1bj's Avatar
1bj is on a distinguished road
does it shake???
1bj is offline   Reply With Quote
Old 10-15-2007, 07:36 AM   #5 (permalink)
Thanks for everyone's input. Does it shake? I suppose it does when it stalls. I decided to take it to the shop and have them look it over. I wanted to try and repair it myself but sometimes you got to bite the bullet. I will update the forum with the results.
Thanks.
Old 12-26-2007, 08:25 PM   #6 (permalink)
gravyk is on a distinguished road
What were your result kind of having the same problems thanks
gravyk is offline   Reply With Quote
Old 01-04-2008, 05:01 PM   #7 (permalink)
RJ1313 is on a distinguished road
Bogs Down
Sounds exactly like my truck a while back
It was the fuel pump located in the gas tank
Easiest access is to remove pickup bed ( sounds bad but is not)
cost about $150 for pump at Advance
RJ1313 is offline   Reply With Quote
