Old 01-21-2008, 04:22 AM   #1 (permalink)
tcbandit is on a distinguished road
keeps blowing seal
I have a 1995 Nissan P/U. I have changed the main seal where converter is 2 times. Something is causing pressure to build up and blows this seal out. Any advice. I am sure that the seal is put on correctly. This will make the 3rd time I have changed the seal in a year.
tcbandit is offline   Reply With Quote
Old 01-21-2008, 04:52 AM   #2 (permalink)
Moderator
possibly the PCV valve needs to be replaced.
Old 01-22-2008, 02:07 PM   #3 (permalink)
Is it leaking engine oil, or transmission fluid? The descrption is a little cloudy. You mentioned the converter, and many transmission leaks are due to a blocked vent in the transmission.
Since you have replaced the seal and you continie to leak fluid, you may have a problem with the sealing surface.
Would like to know a little ore about your application. Should be easy to resolve.
Many times if pressure is allowed to build up, oil simply passes by the seal, and does not really "blow out" the seal. I think that term is used a little too often. Very rare to actually have a seal blow out.
tail light fuse keeps blowing shadygrady Chevy Truck Forum 18 01-08-2008 07:10 PM
truck blowing black smoke Lucys truck Dodge Truck Forum 22 09-01-2007 10:57 AM
Running Lights Blowing Fuse Austinr98 Chevy Truck Forum 0 07-10-2007 03:34 PM
outer window seal on 84 K10 tims84k10 Chevy Truck Forum 2 05-25-2007 02:26 PM
Help 99 ranger xlt blowing coolant into resevoir btooling Ford Truck Forum 16 12-10-2006 08:07 PM
