| Full Member Join Date: Sep 2008 Location: carol stream il
| ok i got a 96 hard body 136,800 miles on her as far as i know she has only had one or two alignments in its life. my friend notices that the camber on the drivers side is getting bad so just wondering if and how to adjust this. thanks for any ideas
__________________ no idea what im doing |
| Take it to an alignment shop. You probably have a torsion bar that is fatigued and requires an adjustment. The torsion on the bars not only affects the ride heigth, it also has an affect on the camber. They can also check the ball joints and make sure you do not have a bad one. |
| thank you for the help
