| Junior Member Join Date: Nov 2008
| 12/86 Nissan vg30 Automatic 4x4 Truck will bog up and down only around 2k rpm but ocassionaly when accelerating. I am a mechanic but this one has me stumped. Any idea's or leads would be awesome! ![]() ![]() |
| well, let's start with what you have checked/tested.
| Has new plugs,cap,rotor,... And wires test good. Have tested coil and control module with known good one's. E.c.u called for a new water temp sender and I replaced it it now has no trouble codes. The O2 sensor is less than a year old as is the cat. No vacum leaks or gaskets. Fuel pressure is good and filter is new. ??????????? Last edited by ron jeremy; 11-28-2008 at 11:21 AM. |
| i would check the maf or like sensors.. sounds like you have checked everything else besides that... |
| did you scan it or use a code reader?
| try pulling vacume line off your egr and re test good luck |
| Tags |
| 4wd |
| Automatic or Manual | russty08 | Polls | 8 | 01-05-2008 12:02 PM |
| 15" nissan Nissan/mazda/toyota/pickup or SUV fancy steel rims. $200 Oshawa | B3VW | Truck Classifieds | 0 | 06-14-2007 12:48 PM |
| automatic headlights | firedispatch1 | GMC Truck Forum | 14 | 10-26-2006 07:51 PM |
| 93 GMC V6 Automatic | 93GMC-V6 | GMC Truck Forum | 3 | 12-21-2005 08:27 PM |
| 2005 Nissan Pathfinder Debuts at Smyrna Plant; Tennessee Governor Helps Nissan Celebrate Manufacturing `Job 1' (StockHouse U.S.) | trucknews | Truck News (headlines) | 0 | 08-30-2004 11:30 AM |
