| 97 4X4 manual transmission Question I am trying to put the transmission back in but cannot get the torsion bars out there is one bolt on the A arm that you cannot get a wrench or socket on anyone know what the best way to get this transmision back in. |
| why exactly do you have to mess with the torsion bars?? are they in the way?? last tranny i pulled like that just fell right onto my belly and i lifted it back up while someone threw in the bellhousing bolts. how did you get the tranny out to begin with?? |
| you must have had the transfer case off I didnt think you could get it off without the torsion bars and crossmember off. |
| i cant recall how that setup is on that. can you remove the transfer case without dropping the Xmember?? |
| Talked to cousin he's a mechanic he looked at it on the computer at work said I could pull a clip and beat the torsion bars off the crossmember off looks like its going to take some heat and pen. fluid. |
| i would like to know this too.
| It should r+r in 2 pieces, drop the transfer then the tranny, reinstall the tranny then the transfer
| Full Member Join Date: Sep 2008 Location: carol stream il
| hey man i have a 96 the best way to get to those bolts is with another person and you have to go through the hood. i hope this works for you good luck!!
__________________ no idea what im doing |
| Tags |
| transmission |
| automatic to manual question | truckabuser | Ford Truck Forum | 3 | 11-15-2008 08:22 PM |
| Manual door lock question | goatman | Chevy Truck Forum | 1 | 06-11-2008 11:17 AM |
| manual transmission stuck in neutral | germeten | Chevy Truck Forum | 1 | 05-04-2008 03:57 PM |
| Electric Widows to manual question | nnunez | GMC Truck Forum | 8 | 12-12-2005 04:30 PM |
| Elusive manual transmission | linuxmann | Chevy Truck Forum | 4 | 08-03-2005 01:46 PM |
