| Junior Member Join Date: Apr 2009
| What Could This Be?? We got a 94 Nissan hardbody 4x4. SE V6 5speed. we had too replace the center support bearing for the driveshaft, ever since then theres a bad vibration in the transmission.. well the shifter stick, it gets worse when you speed up, do you know what it could be? thanks guys, Zach |
| is the u jont bad or did u bend the ring around the shaft |
| we also put a new u joint in it.. the ring isnt bent either!! |
| transmission mount maybe . shd |
| not knowing nissan, is it an aluminum drive shaft? did you hammer the joint out or press it out?
| the joint was taken too a shop. and we just put it back in. it is a steel driveshaft! |
| Im thinkin its the mount too... |
