| oxygen sensor My wife has a 99 pathfinder 2wd. CEL is coming on, when I pull the codes it is telling me it is # 2 bank # 2 sensor heating circuit. My question is which side is # 2 bank so I know where to start looking.
| that's going to be your pre-cat sensor assuming there is only one cat on the vehicle.
| there are 2 cats on the truck and 4 sensors, from what I understand sensor 2 is post cat
| ok, then it would be on the same side of the engine as cylinders 2, 4 and 6 and post cat. Why would a nissan have 2 cats? the dang things have an exhaust pipe the size of a straw and they have two cats!?
| Its a V-6 with 2 pipes into the muffler. The cats are about 4 inches from the manifolds. real easy truck to put on true duals.
| Junior Member Join Date: Jan 2009
| I priced them out on a 1998 and it was like 1400 just for the cats themselves. just thought i would let ya know. I just cleared the code and it never poped back on. |
| rock auto has the cats for 187.00 each. but thats not the problem. mud, can you tell me the testing procedure for the heated oxygen sensors, I don't want to throw parts at it and hope its fixed, thanks
| i just did this on my truck. for mine i connected a test lamp to pin D of the harness side and a good ground, it should light up with the ignition on. next i connected the test light at pins C and D, if there is power there, then you have a wireing problem, otherwise, replace the sensor. might want to have autozone print out something so you know what pins are what for your truck
| Thanks, Ill let ya know how it goes
| Replaced the Oxygen sensor yesterday and so far so good, put some miles on the thing and the code has not come back.
| Oxygen sensor | edward681 | Mazda Truck Forum | 2 | 10-15-2008 06:54 AM |
| Oxygen Sensor replacement--HELP! | jessevargas | Chevy Truck Forum | 18 | 08-08-2008 03:27 PM |
| DIY info on oxygen sensor replacement?? | Ladybug263 | Chevy Truck Forum | 29 | 10-24-2007 12:46 PM |
| Oxygen sensor on 2002 2500 HD | jhughes6060 | GMC Truck Forum | 2 | 10-15-2007 09:57 AM |
| 4 oxygen sensor codes | lugnut | GMC Truck Forum | 1 | 05-02-2007 01:58 AM |
