Old 05-11-2009, 07:22 AM   #1
lhccracker is on a distinguished road
driveshaft removal???
1989 nissan d21 hardbody-2.4 z24, 5spd manual, 2wd, std cab, shrt bed
i am tryin to remove the front shaft (propeller shaft i think) of my 2 pc driveshaft to change my center support bearing. the problem im having is it is not sliding off the splines out of the tranny as i was told it should. the rear shaft is completely pulled the center support is unbolted. is there any kind of retainer to hold the front shaft in place?
lhccracker is offline   Reply With Quote
Old 05-11-2009, 10:26 PM   #2
semocoachworks's Avatar
semocoachworks is a jewel in the roughsemocoachworks is a jewel in the roughsemocoachworks is a jewel in the roughsemocoachworks is a jewel in the rough
The only problem I've ever had seperating a 2 piece shaft is the male end should be teflon coated and I had a freightliner that the teflon had came loose and balled up on the shaft where it joined the female end. I had to take a torch(rosebud) and heat it up to get it apart. I'm not sure yours is the same but i would guess it is teflon coated. Just a thought. Hope it helps. Will the shaft slide at all??
semocoachworks is online now   Reply With Quote
Old 05-11-2009, 10:30 PM   #3
There could be a screw on dust cap on the male end as well. Look and see if it looks like there is a collar that is part of the male shaft that screws to the female side.
Old 05-11-2009, 10:56 PM   #4
hotrodpc's Avatar
Normally is just a threaded dust cap that hold grease and packing in the slip yoke. I'd say its not likely you will hurt it seperating it if you take the cap off. But DO MARK YOUR SPLINES so you put it back togehter exactly the way it came apart or you will throw off your balance. Not positive about Nissan though. How do you intend on getting the old carrier bearing off and the new one on? I have beat them off before. Wow, that did not sound good !!! And beat them back on but found it was just easier and better insurance not to damage anything to pay a machine shop to press it off and on.
Old 05-12-2009, 02:01 AM   #5
The front part of the driveshaft where it goes into the tranny is what wont come out or move at all. neither in or out!! cant see anything that would hold it in unless it spun on the splines(hope not). and as for the bearing....i cant change it till i get the front shaft off. but i was definately goin to have a shop do it as ive heard alot of horror stories from "beatin it off and on" lol.
Old 05-12-2009, 06:47 AM   #6
sometimes they are quite difficult to get off. i have had to take a 5lb shop hammer and wayleigh the tar out of it for several minutes and eventually, it will come off. but you must be mindful of where and how hard you hit that yoke. hit on the hard shoulder and spin around and hit it on the opposite side.
Old 05-12-2009, 12:06 PM   #7
hotrodpc's Avatar
So do you have the flange type that bolts on the rear of the trans? Or is it just a splined joke that goes into the trans? Japs do some funky stuff at times. Maybe its just a seal ring or something of that nature. Do you have a small rubber mallert? Maybe bump it around a bit with a rubber mallet. I much doubt you can hurt anything doing that. Or a pry bar if you can find somewhere to get a bite on it.
Old 05-13-2009, 10:42 PM   #8
yeah its just a splined yoke. but will not move in or out at all with a mallet or prybar or anything. and cant find anything that would be holdin it back. im just worried if i put too much pressure ill break the shaft or trans. but looks like a come-a-long, a sturdy placement, and a lot of pressure is in the near future. thanks for the info and tryin to help!!!
Driveshaft for 2000 Sonoma countryguy140 GMC Truck Forum 1 12-19-2006 09:04 PM
F-350 driveshaft problems 39.5 F-350 Ford Truck Forum 7 11-06-2006 09:38 PM
Front Driveshaft guidorr73 Dodge Truck Forum 10 03-16-2006 06:00 PM
Measuring Driveshaft 85s10383 Chevy Truck Forum 2 07-31-2005 06:25 PM
driveshaft 85s10383 Chevy Truck Forum 7 07-28-2005 12:20 PM
