| Full Member Join Date: Apr 2008 Location: fairfield,ca
| 1991 nissan truck stater removal help so i am trying to help a buddy out by changing out his stater for him but am having some real problems removing the top bolt off the starter. i ended up going as far as draining the oil and removing the oil filter but still no luck getting the bolt to twist and ideas on how to get it loose would be a big help. also i removed what i believe to be the lower bolt but it was only maybe an inch long and i have never removed a stater bolt so short, i see no other bolts around that seem like they connect the starter but that just does not seem right, any help is much appreciated o and the truck is the 6 not 4 cylinder thanks again!! |
| If i remember right the bolts are longer then that! And its a ***** to remove the starter. You need to buy a book at your local parts store Haynes or Chilton. It will tell you how to do almost any repair on the car. It helped me along with this site to replace a timing chain. All most a must have. But their is only two bolts holding it on. Also those bolt heads would be facing the radiator. Just unbolt the wire and remove the two bolts then wiggle it out of the truck. DONT FORGET TO DISCONNECT THE BATTERY TERMINAL!! Good luck and let us know how its going! ![]() ![]() ![]() |
| 1991 Nissan Not Starting | mtscarecrow | Nissan Truck Forum | 1 | 05-03-2008 04:59 PM |
| 1991 b2600i 4wd oil pan removal | flourdude | Mazda Truck Forum | 19 | 04-14-2008 09:07 AM |
| 1991 Toyota truck SR5 v-6 | backwoods91 | Toyota Truck Forum | 6 | 03-31-2008 09:09 PM |
| 15" nissan Nissan/mazda/toyota/pickup or SUV fancy steel rims. $200 Oshawa | B3VW | Truck Classifieds | 0 | 06-14-2007 12:48 PM |
| 2005 Nissan Pathfinder Debuts at Smyrna Plant; Tennessee Governor Helps Nissan Celebrate Manufacturing `Job 1' (StockHouse U.S.) | trucknews | Truck News (headlines) | 0 | 08-30-2004 11:30 AM |
