| im planning on replacing my Nissan's valve cover and gasket. any helpful hints? i'm assuming the old gasket will come off in several pieces or more of a ring of gunk that needs to be scraped off... if thats the case, what is the best tool to scrape the gasket residue off... im sure a chisel is a bad idea, risking scoring/damaging the gasket surface. plastic scraper/putty knife? also, one of the bolts appears to be stripped, and ive heard of 'helicoil' adapters that you can use to fill in stripped thread holes and make them bite again. any tips/suggestions? thanks a bunch in advance!
__________________ 97 Nissan Hardbody SE Kingcab (77k) 86 Yamaha Maxim X (48k) |
| being a 97 it should be a rubber gasket, not cork. helicoils work great, drill it, tap it and done.
| sweet, thanks buddy i'll let ya know how it turns out
| Broken Bolt on the Valve Cover | TNguy08 | Chevy Truck Forum | 6 | 12-07-2008 06:46 AM |
| Valve cover breather caps. | mortar | GMC Truck Forum | 12 | 11-01-2008 06:32 AM |
| timing cover gasket ? | wojeepster | Chevy Truck Forum | 4 | 10-16-2008 07:40 AM |
| 83 gmc lots of smoke and some oil comeing out of the breather on the valve cover | joeydeherrera54 | GMC Truck Forum | 19 | 04-21-2008 05:20 AM |
| valve cover breather tube??? | Pizzaman | GMC Truck Forum | 4 | 12-12-2005 04:40 PM |
