Go Back   Truck Forum > Off-Topic
Reply Off-Topic - Topics not related to trucks or their accessories.
Old 10-16-2008, 01:09 PM   #1
showhaulin' is on a distinguished road
Axle not "true"? What does that mean?
I have a horse trailer that the tire tread wears on the inside a whole lot more than the outside tread. They are properly inflated and the last guy to look at it said that maybe the axle wasn't "true" or "trued". What does that mean, and can it be fixed?
showhaulin' is offline   Reply With Quote
Old 10-16-2008, 01:22 PM   #2
stumpuller454's Avatar
could be bent abit i guess... not sure if thats fixable, i`m sure a guy could farmer fix it! lol
SUPERCHARGED 454 K2500 GMC!
Watch My Youtube Videos!!<<<
Old 10-16-2008, 05:41 PM   #3
sounds like the axle is bowed down when loaded, are you over loading it?
Old 10-18-2008, 06:39 AM   #4
No, it's not overloaded. I only haul 1 horse, and it's made to haul 4.
Old 10-18-2008, 06:52 AM   #5
wild bill's Avatar
wild bill is a name known to allwild bill is a name known to allwild bill is a name known to allwild bill is a name known to allwild bill is a name known to allwild bill is a name known to all
doing it on both side's ? the axle is probably bent and or one spindle is bent ,they build the trailers pretty light now a day's ,barely make weight spec's ,and just snag one wheel on a curb hard and it's done . their is no quick way other than replacing the axle ,once they bend they can go right back .
wild bill is offline   Reply With Quote
Old 10-18-2008, 05:42 PM   #6
does the trailer track to one side as you go down the road?? i have had some that were untrue and tracked indicating that the mounting for the axles didnt line up with the trailer. a bent axle is the other possibility like they said.
a simple test you can do. jack each wheel up and clean the dirt off the tire. rattle can of white to the center while turning the tire and then take a blade screwdriver and make a small line while spinning the tire also. stop the wheels and let it off the jack. with a GOOD and RELIABLE tape measure, measure from line to line that you made. this is a very crude way to tell if you have a bent axle but has worked for me in the past. the two measurements that you get from top and as close to the bottom that you can get, should be the same or real close.
Old 10-23-2008, 05:51 PM   #7
when you look at the axle is the arc pointing to the floor of the trailer,as it should, or the ground?
Old 10-23-2008, 07:16 PM   #8
hi-perfcam's Avatar
hi-perfcam is on a distinguished road
check your wheel bearings!!
hi-perfcam is offline   Reply With Quote
2008 chevy 1500 with 2.5" level kit and 3" body lift bigohagen Chevy Truck Forum 6 06-04-2008 09:33 PM
"help" can't find my power door lock relay switch kealohaboy Ford Truck Forum 2 06-01-2008 04:01 PM
S10 Intermittent "overnight" no start continues ,need help from electrical Guru STRAYDOG Chevy Truck Forum 11 11-09-2006 02:59 PM
