| changed a belt on a chevy corsica today. talk about a pain. you practically have to remove the engine just to get to the darn thing. some genius at GM decided to route the belt around a motor mount, so you have to prop the engine with a jack, undue the mount and snake your hand through the 1 inch space between the engine and the inner fender. even the belt tensioner was weird, the bolt was facing toward the engine so i couldn't use my breaker bar for leverage. took almost 2 hours to do a 2 minute job. if you looked at my arms you would think i was dragged behind a truck on a gravel road.
| Senior Member Join Date: Oct 2008 Location: NW Arkansas
| Thats why I avoid front wheel drives like the plague.
__________________ http://s513.photobucket.com/albums/t...t=HPIM1105.jpg '76 Silverado10 Custom Deluxe, 350 4barrel, th350 auto FULL TIME FOUR WHEEL! |
| i`ve peered under the hood of my wifes new edge, i **** you not i can`t even see the belt! hopefully its not like her last ford car that needed a belt almost once a year!
| Yeah front wheel drive cars suck!! The belts on the older ford escorts are a pain in the ***!!! |
| you know onthe corsica there is a panel you can remove to do the belt... i have changed them many times.. the wife had one when i met her and so did my best friend... lol it seemed like they both wanted to go bad at the same time every year... but for a little front wheel drive car there unstopable inthe snow.. |
| now he tells ya. i had a belt tear up on a fwd dodge van the other day. tensioner was bad. since it belonged to the county, i did what anyone else would have done. i took it to someone else to mess with. already knew better than to attempt that. |
| yeah they suck. We changed the belt's on my g/fs lancer a while back. it was a pita. It has those screw type tensioners and where the bolt was located for both tensioners You only had about 1/2 of room to get the socket/ratchet on it. don't look forward to doing them ever again.
| mud i know what you went through. my mom had a contour v6 and it took me 2 hrs. to replace it and i was cussing the hole time
| Can I 4-wheel drive? | celinaman060 | Chevy Truck Forum | 7 | 06-28-2008 06:58 PM |
| 2 wheel drive to 4 wheel conversion | frank3ks | 4x4 trucks / off road | 6 | 03-31-2008 10:30 PM |
| Wheel Question on my 4 wheel drive??????????????? | 92BlueZ71 | Chevy Truck Forum | 4 | 03-19-2007 05:06 PM |
| 4 Wheel Drive Help? | 97Z71 | Chevy Truck Forum | 5 | 03-04-2007 08:32 PM |
| 4 wheel drive | 92BlueZ71 | Chevy Truck Forum | 1 | 03-06-2006 11:37 AM |
