Go Back   Truck Forum > Off-Topic
Reply Off-Topic - Topics not related to trucks or their accessories.
Old 07-08-2009, 04:28 PM   #11
Thanks for the post stump, I was looking to trick my moped.
It's gasoline now, is the conversion to natural gas hard ?
Old 07-08-2009, 05:05 PM   #12
stumpuller454's Avatar
pretty easy really, you could probly program a stand alone computer and 12 injectors drilled in the the intake to fuel it, although the tank required to hold enough fuel to get across town might be about the size of the engine, i recommend using a trailer to cut down on wind drag.... And the radiator required to cool this thing might be too wide for hwy regs, check your local manicupality....
SUPERCHARGED 454 K2500 GMC!
Watch My Youtube Videos!!<<<
Old 07-10-2009, 02:50 PM   #13
Great tips and guideance !
Don't know why I can't give Rep points for the post.
Keep getting a "pop-up" that says "Stop being silly"
Must be a forum site problem.
Old 07-10-2009, 05:44 PM   #14
They don`t give out silly points...
Old 07-11-2009, 09:13 PM   #15
98k1500's Avatar
98k1500 will become famous soon enough98k1500 will become famous soon enough
Originally Posted by Kennyray View Post
hey Stump, you plan on shoehorning that in your truck? would be a neat trick. Would have to be mid engine to distribute the wieght.
yeah well i got dibs on the charged engine he takes out
GOD BLESS CHRIS LEDOUX!!!
98k1500 is offline   Reply With Quote
Old 07-12-2009, 08:47 PM   #16
semocoachworks's Avatar
semocoachworks is a name known to allsemocoachworks is a name known to allsemocoachworks is a name known to allsemocoachworks is a name known to allsemocoachworks is a name known to allsemocoachworks is a name known to all
I posted this in off topic but for those of you that didnt see it, check this baby out!
The WorldsBiggestCombustion Engine.
The worlds biggest engine is the Wartsila-Sulzer RTA96-C. It is a turbo charged two stroke diesel engine and it is the most powerful and efficient low revolution engine in the world today.
The Wartsila-Sulser is manufactured by the Aioi Works in Japan and is part of Japans Diesel United Ltd engine manufacturers.
Below is an 89 foot long 44 foot wide 12 cylinder engine, literally as big as a house ! What I find confusing is why they haven't actually built the ship around the engine ? How they actually get the 2000 ton engine out of the plant and moreover install an engine of this size into a ship makes the mind boggle.
The pistons travel 16 ft each revolution
These large engines are designed to power the worlds super oil tankers and large container ships. They are built to the shipowners preferences. They usually request an engine construction of a single unit and single propeller design for ease of maintenance, and not surprisingly any later troubleshooting. A single unit and single screw design has also proved over time to have a longer life span than double or even quad screws.
These engines are built in 6, 8, 10, 12 and 14 cylinder configurations. All the engines are straight or 'inline'. The diameter of each cylinder is 3 foot 2 inches with a stroke of 8 foot 2 inches. The 12 cylinder version weighs in at 2000 metric tons and delivers 90,000 Horse Power at 100 Revs per minute, with best fuel economy at 53,244 HP at 90 Rpm.
When I mention economy, the 14 cylinder engine for example with a displacement of 25,480 Litres ( 1.56 million cubic inches ) burns up 1,660 gallons of crude ('bunker') oil every hour.
The Mathematical calculation : 1,660 gallons/per hour = 39.5 barrels of crude oil/used per hour = $2,844. These figures are worked out from the basis of crude oil @ $72 a barrel*.
$2,844 every hour the engine runs or 27.6 Gallons which is $46.00 every minute or 76 cents a second ! That is of course if the ships buy oil at trade price...if not then these figures are the absolute minimum.
( * at time of publishing )
In the image below a worker at the plant is finalising work on the cylinder block. This image shows the piston sleeves. The worker could quite easily have a nap inside one of the bores and no one would notice !
Below are the pistons that will soon be fitted into the engine. Unlike normal car sized pistons these 3 foot diameter pistons incorporate lots of holes and it is through these holes that oil is injected through valves to keep all the working parts at a maximum low wear tolerance. Despite the colossal amounts of power output produced by these engines, surprisingly low wear rates have actually been recorded. Cylinder liner wear for example is only about 0.03 mm down for every 1000 hours of engine use.
It must be remembered here that these engines work at about 20 times slower than a normal 2.0 Litre car engine and this is a major contributor to the life of the engine.
The image below depicts the 300 ton crankshaft of the 10 cylinder engine. You may notice here that there are steps on the wall of the casing to climb down into the engines sump !
In the image below the pistons shell bearings are being fitted into the engine block. They are lowered into place by a crane and guided in by two workers and a supervisor. They keep all surfaces of the engine clean at this stage as any grit or dirt could later add wear to the engine or worse destroy it, so the workers are wearing special cloth overshoes so as not to leave any abrasions on the fine working surfaces. Also you may notice that sheeting is covering the rest of the engines crankcase bearing housing to keep the dust off. These engines cost many millions upon millions of dollars; in fact, more than the ship itself that they are installed into.
100,000 HP was actually achieved on a test bed in the workshop with the 14 cylinder model, running the engine flat out at just under 102 RPM.
102 Rpm may sound slow compared to a normal sized car engine that operates at about 2-4000 rpm, but when an engine is as big as this then fast engine revolutions are made obsolete by the sheer power output.
semocoachworks is offline   Reply With Quote
Old 07-13-2009, 11:03 PM   #17
In this case, the little red x's only show up for those of us with tight security settings.
Old 07-14-2009, 07:40 PM   #18
Sorry crab, I don't know how to fix that. Little insight, this engine is 3 stories tall.
Old 07-14-2009, 09:59 PM   #19
Most folks would never notice, just I keep my computer on a short leash.
This is what I see:
download?mid=1%5f23891%5fAKGzo0IAALvqSUE2NAXBxmN7S 90&pid=7&fid=norton&inline=1&stationery=1
http://f357.mail.yahoo.com/ya/downlo...1&stationery=1
350 motor brad4eva Chevy Truck Forum 6 01-24-2009 11:26 PM
New Motor??? batty1214 Ford Truck Forum 7 12-08-2008 03:29 PM
302 motor liftedtrucks4me Ford Truck Forum 3 02-25-2008 08:34 AM
new motor smokensteve Chevy Truck Forum 3 12-02-2007 08:41 AM
All About Motor Oil Chevy808 Off-Topic 2 12-10-2006 06:15 PM
