| | #71 | |
With the 3' antennas on the mirrors of my truck the tips reach just about 9'6", which just happens to be the exact height of the utility back (including the roof strobes) so I know when entering someplace that if the antennas touch then the truck isn't gonna fit. No need to get out and estimate. Just ease up slow and see if the antenna on the drivers side clears.
| | #72 |
| i knew you could learn me something. ill look into the 3fts then. now about the splitter. how much better is the duals going to work versus the one and having a dummy?? if i have to spend a good bit more on the coax and splitters and such, i might just stick with the single. afterall, i am not talking with the spaceshuttle. i just want to be able to talk with those around me and maybe a few people down the road a spell in case there might be something dangerous around the corner like a bear or city kitty. |
| | #73 |
| Duals will always outperform singles, any day of the week. What you'll find with just a single is that the radiation pattern for the system will tend to be longer in the direction of the most body mass, so if you mount it on the driver's side you'll transmit fairly well to the front and to the passenger side, slightly better to the rear, and very poorly to the driver's side. Switch it to the passenger side and you'll transmit better towards the driver's side, but very poor to the passenger side. This is why, when using a single antenna, you want to try to center it on the vehicle. But, with a true co-phased setup, you greatly increase your range ahead and behind, and have very good range to either side. If you can afford it then duals are the way to go.
| | #74 |
| Oh, and you don't need anything "special", just a co-phased harness. It's like a regular coax lead except there's two cables coming out of the plug on the back of the radio, one for each antenna. Not much more expensive than a single.
| | #75 |
| It appears I have missed this thread. As with many things, I know just enough to get into trouble and think I have installed the antenna's right and I probably haven't. However, I really do not use a CB much anymore since the speed limits have been raised to 65, 70 and 75 on the interstates, the truckers usually do not give Bear reports anymore being that many of the truck are governed at 65-70mph and not speeding anymore. I still would like to have a CB in my box van though. I have never done it because the box is fiberglass, and antenna mounts will not ground to fiberglass. I do not want to use mirror mounts because I eventually intend to replace my metal door mounted mirrors with later model mirrors that are plastic and mount in the vent glass area of the door instead of the sheet metal, therefore, that also will not be grounded. I have thought about putting antennas on the rear steel bumper, but those would have to be some pretty long antennas to clear the box. Anyone got any ideas? I sold my nice Cobra 29 with mod kits. That thing got out real nice. I might get me another one someday for the box van, if I could figure out a good way to get some nice antennas installed.
| | #76 | |
The only problem I can see you having with the box truck is picking a good mounting location. The roof would be great, but with any decent antenna you'd be well over 14', so that's not a great idea, but... There's another way, and rather sneaky to boot... Mount it inside the box, hanging upside down from the roof.
| | #77 | |
Here is a pic of the base unit I received from the lady I work with's boyfriend.
__________________ ENGINES PRODUCE POWER. MOTORS RECEIVE POWER.![]() https://lastroundbestround.com/Home_Page.html | |
| | #78 |
| Ooooo... Is that a genuine D-104 mic I see there?
| | #79 | |
__________________ Winners NEVER Quit , Quitters NEVER Win !!! | |
| | #80 |
| I oughta dig out my grandparents old base system I think I still have it along with a mic very similar to that one, if not the same thing. Gma and Gpa were mega into their CB's. About like us and our computers.
| Tags |
| antenna, cb radio |
| xm radio? | og25 | Off-Topic | 5 | 05-08-2009 09:40 AM |
| Wtb-gmc oem radio | mtebaldi | GMC Truck Forum | 1 | 04-23-2009 02:18 AM |
| New radio | bigcountry78 | Chevy Truck Forum | 42 | 12-02-2008 10:49 PM |
| radio | 2wdramman | Dodge Truck Forum | 1 | 06-05-2007 06:37 AM |
| Radio help | PickUpGirl787 | Chevy Truck Forum | 3 | 01-12-2007 06:25 AM |
