Go Back   Truck Forum > Other Trucks
Reply Other Trucks - Any other trucks not already covered.
Old 04-29-2007, 04:22 PM   #1
testing fuel injectors
how do you test fuel injectors on a fuel rail? i gotta buy a pressure gauge in the morning to see if the pump is working right, but want to test the injectors also. i don't want to replace the injectors unless i need to, they cost 50 to 100 dollars a piece depending on the brand. this is on a 93 oldsmobile cutlass. it's gonna be the new daily if i can get it running right. can't afford the gas with my hours getting cut, paying for college and the extra miles each week.
Old 04-29-2007, 06:00 PM   #2
436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold436'd skylark is a splendid one to behold
injectors really don't go bad. they got clogged up full of junk. Is it the 3.1 or 3.3? I'd pull the rail and clean them out, and the rail. Car might need a coil pack. They are notorious for that.
Joe
1962 Scout 80 parts I guess
1966 Scout 800 resto job
1996 P30, 6.5 NA Mac Mobile
whole lot of buicks
Old 04-29-2007, 06:08 PM   #3
you got the devils luck with your mama, the truck, and you job. i have questioned how to test injectors and all that anyone has told me is that some shops have them but not many being that it is an extreme specialty tool. cant tell you any more than that. sorry
Old 04-30-2007, 04:25 AM   #4
it's got the 3.3 in it. the cars been parked in the garage for about 3 years and it just seems to be stumbleing over itself for the last few months. the fuel rail was clean and shiny when i removed the injectors, but there didn't seem to be much fuel coming out of the injectors. i was wondering if i could test the injectors and the harness with a multimeter. it's like junior said, bad things happen in threes.
Old 04-30-2007, 06:35 AM   #5
the injector is a small solenoid that opens and closes. it doesn't spray, its only a valve that opens and closes. the pressure in the rail is what shoots the fuel. If you verify the fuel pressure is good, then you likely have a bad crank position sensor or a coil pack. I can't emphasize enough to check fuel pressure on every diagnose problem. I've must of said that two dozen times on this board already..
Joe
whole lot of buicks
1987 throttle body fuel pump problem wojeepster Chevy Truck Forum 11 10-28-2009 01:53 PM
2001 2500HD 6.0L 4x4 Power Issue - Lean Fuel nicholwa Chevy Truck Forum 5 10-28-2009 05:49 AM
1993 Crew Cab Dually- Fuel pump problem? RodrigoRodrigo Chevy Truck Forum 2 02-26-2007 04:27 PM
Fuel System Issue - 1989 4x4 4Runner HKforte Toyota Truck Forum 1 01-11-2007 05:41 AM
Contaminated fuel system Phil R Chevy Truck Forum 2 07-23-2006 12:00 PM
