Toyota Truck Forum - Toyota pickup truck forum, etc. |
#11 (permalink) |
starting problem
hey you may want to disconnect the cold start injector. IO have an 88 4runner had the same prob. the computer tells the motor its cold when its not and floods it out I wired mine into a switch now it works fine. Plus when its wired into a switch you can test it
#13 (permalink) | |
Wiskey Chick, you mite try checking your start injector time switch. |
#14 (permalink) |
found it!!!!
found the trouble. can't believe it was soooo simple.
my gas cap was bad. replaced it and the truck fires up on the first revolution just like new. cost me about $12 because i wanted one that locks with a key, but a basic cap can be had for around $6. thought i would post this just so somebody else having a hard starting problem mite try it befor they get too deep into analyzing the fuel system. always try the easy (and cheap) things first. thanks to everyone for your replys. on the bright side, my truck got a good tune up and i learned a lot about my truck and engine. thanks again, Mike. |
| Starting Problem | njk53 | Chevy Truck Forum | 2 | 02-05-2008 04:39 PM |
| 76 hard time starting | 76truckin | Chevy Truck Forum | 4 | 11-09-2007 11:32 AM |
| 7.4L Hard Starting | elkfool | Chevy Truck Forum | 6 | 12-31-2006 09:02 AM |
| Hard starting, sluggish when cold. | prowler40 | GMC Truck Forum | 2 | 11-06-2006 07:09 PM |
| Problem starting | Keith23 | Chevy Truck Forum | 3 | 03-10-2005 08:43 PM |
