Go Back   Truck Forum > Toyota Truck Forum
Reply Toyota Truck Forum - Toyota pickup truck forum, etc.
Old 02-28-2008, 09:44 AM   #1
jirwin is on a distinguished road
90 Toyota Lost Power "The Get up and go"
Today on the the way to work, my 90 Toyota truck lost almost all moving power "the get up and go" while going down the interstate.
-Motor is running fine
-fluid levels fine
-clutch (shifting into/out gear as normal).
-There is just no power in any gear. The bell housing was smoking (smelled like burning clutch), except i had shifted barely at all, got up to highway speed and continued down the road @ 55mph, then lost power- pressing gas and was slowing down.
Please help? Clutch slippage? Tranny? Thanks, ahead of time! ---J
PS: Truck Specs:
1990 Toyota
22RE-4 cyl
5 spd
4x4
107,000 orig miles-new timing chain &acces @ 99,000
last clutch change @ 70,000
jirwin is offline   Reply With Quote
Old 02-28-2008, 10:03 AM   #2
junior3382's Avatar
Location: Currently, I live in Lancaster country, Pennsylvania.
When you lost power, was just forward motion? I mean the RPM's climb but nothing to the wheels? if not, it may not be the clutch. You said fluid were fine, tranny fluid too? When was the last tune up? With that I mean actual plugs wires etc. I assume it was at 99k sicne you did timing chain, but you did not specify.
These are all questions that would help narrow down. However, based on just what you have here, her is my thought. I had a fried with an older Caprice with this exact same issue. NO GO. it even slowed down hill with the accelorator floored. It turned out to be a plugged converter. Now you mentioned smoke around the bell housing, it is possible if the conmverter was over heating, it could have just looked like it was from the bell housing. Now granted, they get red, and I mean bright red if they are plugged and get hot, so it would be easy to see. I would venture to guess that was the problem, unless of course your RPM's were going nuts with no go, then it could be the clutch.
Lets get some mud on the tires...eh?!?!?
OWN:
1998 Chevy Blazer ls 4x4
4.3l Vortec V6
1998 Mazda B3000 SE 4WD
3.0L V6
3" lift
31x10.50 Liberator A/T's
Old 02-28-2008, 10:20 AM   #3
Yep, rpms climbed high little/no power to wheels, very slow to accelerate.
Last tune up at 104,000 plugs, button, cap, air filter
yes, @ 99k :timing chain sprokets, guides: valve clearance checked, oil pan gasket, valve cover gasket, timing reset using timing light gun.
thanks.
Old 02-28-2008, 10:46 AM   #4
junior3382's Avatar
if the RPM's were climbing with no acceloration, then yes it would be your clutch. Could be possible even with only 37k on it. I would consider a replacment there.
OWN:
4.3l Vortec V6
3.0L V6
3" lift
Old 02-28-2008, 10:48 AM   #5
Thanks, that was my thought, just wanted other opinion. clutch w/ only 37k yep, haynes manual says replacement normally at 40k (on clutch) for this truck. well on the price search. thanks for the help. J
The "lift bed" Procedure for R&R tank mounted fuel pump? Shox Chevy Truck Forum 4 02-16-2007 12:01 PM
S10 Intermittent "overnight" no start continues ,need help from electrical Guru STRAYDOG Chevy Truck Forum 11 11-09-2006 03:59 PM
New Dodge "POWER WAGON" BamaDodge Dodge Truck Forum 7 05-04-2006 09:22 AM
2000 silverado 1500 5.3 "miss" at idle WDDOBLER Chevy Truck Forum 7 02-02-2006 06:44 PM
Pics of "Older model ford for sale" Blazerunner Ford Truck Forum 1 09-15-2005 01:18 PM
