| Junior Member Join Date: Oct 2008
| newbie needs oxygen help Hey all, landed here by random surf. My girlfriend has a 1998 Tundra w/ 2.4L. The oxygen sensors need to be replaced.The one under the hood Helen Keller could find. There is supposed to be another one somewhere else on the truck we haven't had a whole lot of luck finding it or a manual that shows it. Can anybody throw us a bone on this? Thanks Mike |
| it would be located after the catalytic converter, which is more than likley located under the vehicle.... |
| Thank you Stumpuller454, the catalytic converter was exactlly where you said I"d probably find it,and the **** sensor was loitering in the same spot. I can build you a piano from a picture, but the car thing kicks my butt. Have a great day |
| Welcome to the site: What are the odds of two sensors going bad at the same time? Are you sure there is not another problem? Once in a while simply dirty injectors can cause a lean cylinder that will result in a random misfire code, and often can come back as a bad O2 sensor. What gave you the indication that the O2 sensors were bad? |
| Oxygen sensor | edward681 | Mazda Truck Forum | 2 | 10-15-2008 05:54 AM |
| Oxygen Sensor replacement--HELP! | jessevargas | Chevy Truck Forum | 18 | 08-08-2008 02:27 PM |
| Oxygen sensors... | usmceric1 | Chevy Truck Forum | 2 | 05-29-2008 09:19 PM |
| 4 oxygen sensor codes | lugnut | GMC Truck Forum | 1 | 05-02-2007 12:58 AM |
| oxygen sensors? | braydee0521 | GMC Truck Forum | 3 | 03-20-2007 07:26 PM |
