Go Back   Truck Forum > Toyota Truck Forum
Reply Toyota Truck Forum - Toyota pickup truck forum, etc.
Old 01-31-2009, 01:51 PM   #1
joeking2u is on a distinguished road
deiseling
Hi I have a 91 toy 4+4 pickup(22re) Recently I replaced the engine with a Jasper but I have an ongoing problem(not why I replace the engine) It seems when ideling my idel speed keeps fluctuating up and down( deiseling)I think it may have something to do with some sensor but I dont know .Does any one have answers?
thanks Joe
joeking2u is offline   Reply With Quote
Old 01-31-2009, 01:56 PM   #2
IAC could be a culprit. another thought would be a buildup of carbon in the throttle body restricting air flow through the butterfly.
Old 01-31-2009, 03:06 PM   #3
deiseling
Whats IAC?
Old 01-31-2009, 04:18 PM   #4
idle air control valve. it is mounted on the throttle body. its purpose is to read the amount of vacuum entering the intake so that it can adjust your fuel to idle purposes. when removed, you will find a plunger. this is how it determines vacuum. when faulty, it will not let the engine idle and causes the engine to die. i would look at cleaning the throttle plate first and then look at a fuel filter change. if both look good, refer back to the IAC.
Old 02-01-2009, 01:47 PM   #5
Thank you Ill try it
Joe
Old 02-09-2009, 05:18 PM   #6
ray in ma is on a distinguished road
Having the same problem on 97 Chevy 5L 8CY
Changed the fuel filter, changed cap & rotor, new plugs & wires even replaced MAF sensor. When I had the resonator off to change cap - rotor - wires, I sprayed into the top of throttle body with stuff from NAPA marked for it
Check engine light came back on today with code 102 'Volume Air Flow Circuit Low Input' Can't seem to find a picture of what the unit looks like in the Chiltons. Is this a straight forward repair or should I take to mechanic?
ray in ma is offline   Reply With Quote
Old 02-09-2009, 08:12 PM   #7
dieseling has always been referred to the run on of an engine after turning the key off
Joe you tacked onto the thread of a different type of vehicle, with what sounds like an erratic idle. Have you checked for vac leaks?
Old 02-18-2009, 04:02 PM   #8
deiseling
You were absolutely right about the term dieseling but someone gave me a "heads up " about decreasing my idle and so far my problems solved
