Go Back   Truck Forum > Toyota Truck Forum
Reply Toyota Truck Forum - Toyota pickup truck forum, etc.
Old 05-12-2009, 08:49 AM   #1
jeremiah is on a distinguished road
cracked block in a 22re
i have a question. i have a 1994 toyota pu with a 22re and i cracked a block and i was wondering if i could replace it with a 22r block... does anyone have any advice?
jeremiah is offline   Reply With Quote
Old 05-12-2009, 10:53 AM   #2
any reason why you want to go to a non EFI controlled engine?? you cannot expect this block to bolt right up and everything work just like the old one if that is what you are thinking.
Old 05-12-2009, 10:58 AM   #3
i bought another truck for the engine. it has a 22r in it. but its not the same? can i use it at all?
Old 05-12-2009, 11:04 AM   #4
why wouldnt it fit? i just want to use the block not the heads. if it wont fit what can i do to make it work?
Old 05-12-2009, 11:49 AM   #5
i would like to retract my previous statement. finally got some lunch in me and started thinking clearly. it should work. the only problem i foresee is that you will no longer have somewhere to install the knock sensor. really cannot tell you what to do to solve this problem though.
Old 05-12-2009, 12:29 PM   #6
and i am guessing that it wont run unless i can get that hooked up huh?
Old 05-12-2009, 01:22 PM   #7
it should run but your timing will not advance any to gain mileage needed on lower octane gas such as 89. there should be a way but i really dont know how.
Old 05-12-2009, 01:41 PM   #8
well i appreciate it. i am goin to try to put it together and see what happens. thanks
22re Idle scatter Toyota Truck Forum 4 05-18-2009 04:33 PM
question on 22re and block seal tri5ron Toyota Truck Forum 2 04-23-2009 09:22 PM
1965 352 V-8 Small block or big block RoadHammerTLM Ford Truck Forum 7 01-10-2009 10:59 AM
Chip for 22re? knj27 Toyota Truck Forum 1 02-29-2008 06:31 PM
transmission mounts cracked sat1962 GMC Truck Forum 1 02-18-2008 08:19 PM
