| 91 Toyota Surge problem? I have a 91 Toyota 2 wheel drive pick up and have been having a problem with it surging as I am driving. I first noticed it on the freeway as I maintained constant speed. It would only surge for a second or two and then go away. This is very sporadic and does not happen at any certain time or speed. If I accelerate the problem would stop. I changed the fuel filter, thinking it may have been partially blocked; but no improvement. As part of regular maintenance I recently changed the spark plugs and this only seemed for make the problem worse. Now when the truck is cool it runs as it did before, but when it warms up it is hard to accelerate. Now when I am at idle the engine is running very rough. I am at a loss and trying to figure out what the problem is. If anyone can help me, it would be greatly appreciated. |
| | #2 | |
| Senior Member Join Date: Nov 2008 Location: West Covina, Ca
Otherwise, I would look into the MAF sensor. You might have an air fuel regulation problem at idle as you mention it behaves normally under accelerattion when on the freeway. That would be my best guess. Hope it helps!
__________________ '99 F350 5.4L crewcab Longbed | |
| Thanks, I will give it a try. |
| Hey Yota man! just curiouse if you managed to fix er up yet and what the problem was?
| 89 Toyota Truck charging system problem | CWA OldTimer | Toyota Truck Forum | 3 | 09-29-2008 12:46 AM |
| 88 toyota truck problem | nova 63 | Toyota Truck Forum | 1 | 01-21-2008 10:14 AM |
| Howdy :) Got Toyota 4X4 PK UP Problem | drealynn | Toyota Truck Forum | 5 | 06-24-2006 09:05 AM |
| lifting my toyota pick up, big problem wrong info published. | 2fast4u | Toyota Truck Forum | 8 | 01-08-2006 09:47 AM |
| Toyota to Triple Argentine Truck Production Amid Surge in Sales (Bloomberg.com) | trucknews | Truck News (headlines) | 0 | 08-26-2004 05:30 PM |
