| 89 Toyota pick up 4 cyl no spark Hello, every one this my first post here I hope to learn and contribute as much as I can. I've got an 89 toyota pick up 4cyl fuel injected. Replaced igniter, coil and still no spark. I really need to get this thing going any advice would be appreciated. Thanks |
| 22re. do you have a hot at the coil?? not the coil wire but the + side of the coil?? if yes but nothing coming out of the coil, than you could have a pickup coil problem. what all have you tested so far?? |
| Pickup coil is tested good. Replaced the coil and the igniter. Tested it all timing belt on and intact. What do you suggest? |
| see if you can follow me on something. check in this order. check resistance of the plug wires. max is 25 Kohms per cord. check power supply to ignition coil. resistance cold should be .5 to .7 ohms on the primary. measure this between the + and - terminals. resistance on the secondary should be 11.4 to 15.6 Kohms. this is between the + terminal and the coil wire terminal. check resistance of the pickup coil. 140-180 ohms. check air gap of dizzy. should be .2 to .4 mm. this will be the gap between the signal rotor and pickup coil projection. if any of this checks bad, replace it. if all that checks out, get back with me and i will refer back to my service manual. Last edited by bradrhale; 08-27-2009 at 08:22 PM. Reason: forgot something |
| I'm going to be a lil while I get get my buddy with the equipment back over to help me get all these readings and see if anything needs replaced. So If you don't hear from me in a couple days I'm still going to working on it. ASAP! I thank you for your time. |
| reason i listed all that is so you wont have to spend on the extra money replacing parts tht need not replacing. i know its alot but really the only thing you need is the multimeter. should not take you that long to figure out. walmart sells a knock around multimeter for 20 bucks i think, if you dont own one. |
| 1994 toyota 2x4 pick-up truck torsion bar replacement | mickfergusonusa | Toyota Truck Forum | 0 | 11-08-2008 12:08 AM |
| 1991 Toyota Pick-up V6 No start | notmytoyota | Toyota Truck Forum | 1 | 01-21-2007 07:44 AM |
| lifting my toyota pick up, big problem wrong info published. | 2fast4u | Toyota Truck Forum | 8 | 01-08-2006 09:47 AM |
| Pick me up with your Pick-Up (Sun Star) | trucknews | Truck News (headlines) | 0 | 12-05-2004 09:30 PM |
| Toyota Begins Producing Decks for Tacoma Pick-up Truck in Mexico (Japan Corporate News) | trucknews | Truck News (headlines) | 0 | 09-21-2004 03:30 AM |
