Results 1 to 7 of 7
Thread: 94 pick-up
    Nov 2009
    4
    94 pick-up
    Just got a 94 pu, 4cyc, man., 2wd. No emblems on it anywhere so I'm guessing it's a base model. The fuel pump doesn't run when you first turn on the key. Is there a fuel cut-off/inertia switch somewhere or something else to look for before pulling the pump? Also, what size motor is it. Thanks
    Nov 2009
    winchester, va
    4,173
    A 94 toyota Pickup What modelis is it?
    Nov 2009
    4
    Quote Originally Posted by ranger2001 View Post
    I don't know. Just a 1994 Toyota pick-up.
    Nov 2009
    winchester, va
    4,173
    got pics of this truck to post. what is this a v6 or v8? Got vin to post so somebody can look it up by the vin for you.
    Nov 2009
    4
    2.4, 4 cylinder. I figured out the motor size.
    Nov 2009
    winchester, va
    4,173
    So what saying is the truck won't start and you don't hear the fuel pump come on when turning the key forward right? If so check for a fuel pump relay first.
  7. #7
    Nov 2009
    4
    Quote Originally Posted by davbell22602 View Post
    OK I'll try that first. Thanks
  1. 95 pick-up tps problem
    By dejast in forum Nissan Truck Forum
    Last Post: 10-23-2009, 12:19 PM
  2. pick up coil
    By yj94 in forum GMC Truck Forum
    Last Post: 04-27-2008, 07:50 AM
  3. Pick your pet wisely...
    By crabtruck in forum Off-Topic
    Last Post: 03-30-2008, 01:45 AM
  4. 1995 pick up
    By tcbandit in forum Nissan Truck Forum
    Last Post: 05-30-2007, 12:39 PM
  5. Pick me up with your Pick-Up (Sun Star)
    By trucknews in forum Truck News (headlines)
    Last Post: 12-05-2004, 09:30 PM
