Results 1 to 5 of 5
Thread: 91 toyota p/up crank no start
    Jun 2010
    3
    Need help with a 91 Toyota P/Up that will crank but no start. Any suggestions. I have tried to pop the clutch while being pulled, the engine will crank over but once I hit the gas its boogs down.
    Platinum Member
    Feb 2006
    michigan
    8,677
    welcome to the forum.
    to start, we need a little more info from you.
    engine?
    history that lead up to this problem and what you have tried so far woud be a great start.
    Jun 2010
    3
    Engine is 2.4L L42BL. It is a custom truck that I do not drive a lot and has sat for a little while. I have drained the old gas out of the tank and lines. I have removed the starter and had it tested to make sure that wasnt it either. The truck used to run fine before it sat. I have jumped it before by poppin the clutch while being pulled. The engine is completely rebuilt and has around 25000 miles on it. When I turn the truck on I can hear the pump turn on.
    Platinum Member
    Feb 2006
    michigan
    8,677
    sounds like you just need to clean the carb. i play with newer engines, so am no help, but others will reply sooner or later.
    Jun 2010
    3
    I dont think its an intake issue, it is just not getting any fuel. anyone else have any ideas
  1. 96 gmc k1500 crank, no start after engine swap
    By timsmothers in forum GMC Truck Forum
    Last Post: 12-20-2009, 11:25 PM
  2. 87' S15 Jimmy - No Start / No Crank ?
    By oscar in forum GMC Truck Forum
    Last Post: 11-02-2009, 04:42 AM
  3. 1991 Toyota Pick-up V6 No start
    By notmytoyota in forum Toyota Truck Forum
    Last Post: 01-21-2007, 07:44 AM
  4. New to Forum and need HELP!! Bad Crank???
    By 61unibody in forum Toyota Truck Forum
    Last Post: 08-01-2006, 04:37 PM
  5. s10 won' crank
    By steve39475 in forum Chevy Truck Forum
    Last Post: 03-28-2006, 06:14 PM
