Results 1 to 7 of 7
Thread: 1992 Toyota Truck cold start problem
    Jan 2011
    2
    1992 4x4 22r, efi, won't start when its really cold outside. It cranks fine when its warm out, even it has sat for days. On cold mornings it turns over fine, may even act like its going to start, but won't. I can crack open the air filter canister, spray a little either at the edge and it will crank up fine, idle fine and crank the rest of the day. The next morning if its cold out, the same thing. Help! Thanks.
    Senior Member TexasAirCooler's Avatar
    Feb 2010
    Lone Oak TX
    139
    Check your cold start injector.
    When was the last time you ran some injector cleaner through the tank?
    Terry
    '99 Chevy Tahoe daily driver
    '99 GMC Sierra 2500 Crew Cab big block farm truck
    '96 Chevy Suburban
    '65 13 Window Deluxe VW Bus restore project
    Jan 2011
    2
    cold start injector
    How do I check the cold start injector and where is it located? I ran injector cleaner through it a few months ago.
    Feb 2010
    Lone Oak TX
    139
    Looks like it's time to buy you a repair manual, Chilton and or Haynes.
    Terry
    '96 Chevy Suburban
    Jun 2011
    San Bernardino County
    18
    The cold start injector is mounted to the upper air intake manifold just above the level of the valve cover. It's more likely that the cold start switch or it's connector has gone bad. At this point you really do need a service manual to correctly troubleshoot this circuit.
    Dec 2011
    ark
    2
    got an88 donebe the same thing replaced cold start injector and cold start timing sensor no help but i changed the fuel pump and it seems to be working now the strainer was gone off fuel pump
  7. #7
    Feb 2012
    1
    Many cars doesn't start in cold days, but in Asia where less cold cars starts easily. I have Toyota Tundra 2008 model and sometime it creates problem to start.
  1. 92 c2500 cold start problem
    By silverado636 in forum Chevy Truck Forum
    Last Post: 02-24-2010, 07:57 PM
  2. Headlight problems on 1992 Toyota 4wd
    By Smitty86 in forum Toyota Truck Forum
    Last Post: 12-21-2009, 02:28 PM
  3. 1992 Toyota
    By tbs1970 in forum Toyota Truck Forum
    Last Post: 09-25-2009, 10:50 AM
  4. 95 cold start problem, revised comment
    By sparky1435 in forum Chevy Truck Forum
    Last Post: 07-09-2009, 05:05 AM
  5. 95 cold start problem
    Last Post: 07-07-2009, 07:31 PM
