Go Back   Truck Forum > Toyota Truck Forum
Reply Toyota Truck Forum - Toyota pickup truck forum, etc.
Old 07-11-2005, 05:37 PM   #1
80ToyotaPU is on a distinguished road
Carb. REbuild
ok im looking at rebuilding my carb. had it ordered with the flot, and will get it tomarrow at 1pm then the fun Begins. how hard is it? it looks easy in the shop manual.and should i expect any surprises?
80 toyota pick up: bench seat and up graded stearo
http://www.cardomain.com/member_page...ride=member_id
80ToyotaPU is offline   Reply With Quote
Old 07-11-2005, 05:51 PM   #2
Ford4x4Chik27's Avatar
It's not too bad, as far as I can remember, rememeber what linkages go where and don' let nothin get inside The tuff part is adjusting it once you get it rebuilt
Good luck!!
Old 07-13-2005, 04:58 PM   #3
Well, it went well. It was not hard at all just took a lot of time. The two are different very different. after bolting it back on and starting it up ran fine for over 20 min. took it up the street and ran fine tell I had to turn it around and lost all power and died would start. it a manual so I tried pop starting it still nothing walked home and called mom to pull me home(the only one who will help me if I need it) got my jeep then picked up mom and went to my truck. Tried to start it again, still nothing check to feel any leaks and its wet. Then smelled it and it was gas. In the morning, I either fix it or burn it.
Old 07-13-2005, 05:05 PM   #4
D'oh! So maybe a gasket or oring is leaking?
*scratches head*
Old 07-14-2005, 06:47 PM   #5
Well I pulled it off and CHECKED EVERY thing. It all was good. The float is set correctly and the needle is fine and was not jammed. Put the carb back on and tried starting it when it started it ran as if it was being flooded. The little glass piece is FULL of gas. I know its supposed to be half gas and half air but its not. and the adjustment screws seem not to help. is it still the float? or some thing else that my control the amount of gas it gets?
Old 07-14-2005, 07:15 PM   #6
It could be your float, or your idle is too high
Old 07-19-2005, 04:01 AM   #7
Ford_DOC's Avatar
Ford_DOC is on a distinguished road
Wow I wish i could help you out but carbs and I do not get along...
Good luck
That will be 8 ummm 900 bucks!
Ford_DOC is offline   Reply With Quote
Old 08-11-2005, 07:25 PM   #8
its been awhile and still having problems good thing its not my only vehicle I think I’ll take it in and get it working properly when I don’t know classes start Monday the 15th and will be busy but oh well.
Old 08-12-2005, 07:59 AM   #9
Maybe it's not your carb...maybe it's something else I.E. clogged fuel lines/filter, messed up sensor, something like that.... I dunno just an idea
Old 08-12-2005, 09:57 AM   #10
i changed those already not the proplem its the carb.
Timing or Carb Issues ???? runedawg Dodge Truck Forum 10 11-18-2005 05:55 PM
Nv 4500 tranny rebuild tutorial/guide tonyseahawk Chevy Truck Forum 0 06-04-2005 04:40 PM
nv4500 rebuil turorial/manual tonyseahawk GMC Truck Forum 0 06-02-2005 04:04 PM
carb problems F150on40's Ford Truck Forum 3 01-05-2005 07:52 PM
Info On 350 Rebuild For 1992 Chevy CUSTOMRODS Chevy Truck Forum 1 12-01-2004 03:09 PM
