| Junior Member Join Date: Apr 2006 Location: Northern Virginia
| I have a '94 regular cab 4x4. I already had to pull off the rear bumper b/c of severe rust. Now I see that the passenger side rear leaf spring bracket is about to fall off b/c where it attatches to the frame, rust has completely eaten the metal away. Has anyone else had this problem? If so, what did they do to fix it? Thanks |
| i would treat it with some rust killer and then have it undercoated.
| Unfortunatly the toyota'a are prone for getting ROT in that area. I thought after 88 they fixed the problem tho. Guess not. Your best bet is to take it to a good welding shop and have the ROT cut out and a new piecs of steel welded in and a new spring mount put on. The shop should be able to tell you if the metal there is savable or not as well. I had to get some frame work done on my 87 this past December. More than you need done but its a Toyota and worth it. |
| while you're there, I'd have them inspect the whole frame, and especially the crossmembers for other potential weak points to save you the hassle of making return trips.
__________________ 97 Nissan Hardbody SE Kingcab (77k) 86 Yamaha Maxim X (48k) |
| old thread......
| 1997 chevy tahoe gage light problem | bajaboy | Chevy Truck Forum | 5 | 03-23-2006 08:58 AM |
| Abs Problem??? | MARK326 | GMC Truck Forum | 1 | 12-30-2005 01:01 AM |
| Rust Rust Rust!!!!! 97 2500 4x4 Diesel | Big Diesel | Chevy Truck Forum | 5 | 11-18-2005 09:03 PM |
| chevy s10 fuel injector problem... | rrodriguez190 | Chevy Truck Forum | 8 | 10-30-2005 12:23 AM |
| Diesel problem | jgn | Dodge Truck Forum | 2 | 06-01-2005 05:22 PM |
