| Senior Member Join Date: May 2006
| Dome light not working correctly When it is in the position for it to turn on when the doors are open, it does nothing...It worked the first day i had it, but since then, nothing. There is only one fuse that controls the dome light as well as a couple other things, it isn't blown, and the light works fine in the on position, just nothing for the door position. |
| sometimes my dome light won't come on when the door is open either, but it works at the switch. if i hit the dash where the switch comes in contact with the door when it is closed it will come on, some kind of short or something. haven't had a chance to tear into it so i couldn't tell you the exact problem or if it is the same problem you are having, but i would check the switch and go from there.
| 2000 ford f350 door ajar light problem | be4969 | Ford Truck Forum | 3 | 05-29-2006 09:07 AM |
| F350 diesel door ajar light problems | be4969 | Introductions | 2 | 05-24-2006 02:06 PM |
| Engine and overdrive light | chief | Ford Truck Forum | 2 | 03-30-2006 07:27 PM |
| Check Engine light and overdrive light on | chief | Introductions | 0 | 02-05-2006 08:12 AM |
| 89 Ranger tail light problems | dangerranger89 | Ford Truck Forum | 4 | 11-28-2005 03:55 PM |
