| Junior Member Join Date: Jul 2006
| I have 2000 2.7 engine that at a steady speed going down the road the truck jerks alittle. I have replaced plugs,fuel filter,cleaned throttle body,tps,. Can any one help with this problem? I thought it might be in the engine,but thinking it could be in the transmission,I am replacing transmission filter today. This truck has 103,00 miles. Thanks. |
| you say that it jerks a little and i am finding it hard to believe that it would be in the tranny. whenever a gear is slipping in and out of a tranny, like its not getting enough fluid, usually jerks pretty heavily when it is going from gear to gear. have you had it checked for any codes?? |
| | #4 | |
| Junior Member Join Date: Aug 2006
| Have you tried a good fuel injection cleaner... Assuming it is FI.. I think it is though. |
| Are you sure it's comin from the motor and not the steering or chassis? It could be a clogged fuel filter, bad fuel injector, or maybe a sensor...?
| i dont believe that it is going to be a sensor as there are no codes and he just changed the filter. would a bad injector pull a code?? might be a possibility |
| I dunno if a bad fuel injector would pull a code, but I do know that it'd cause a vehicle to cut out and jerk a bit
| you got that right |
| Junior Member Join Date: Feb 2007
| Did U Make Sure Ur Suspension Is Not Blown? |
| Need Good Toyota Repair Shop in Sacramento | lkirby | Toyota Truck Forum | 1 | 07-24-2005 10:54 AM |
| '79 Toyota 4x4 | Ford4x4Chik27 | Toyota Truck Forum | 5 | 06-23-2005 09:50 PM |
| NEW: 18 suppliers will move on site at Toyota truck plant (San Antonio Express News) | trucknews | Truck News (headlines) | 0 | 12-16-2004 11:30 PM |
| Toyota Begins Producing Decks for Tacoma Pick-up Truck in Mexico (Japan Corporate News) | trucknews | Truck News (headlines) | 0 | 09-21-2004 03:30 AM |
| Toyota Tundra Thunders By Field at Michigan- Kvapil Captures First NASCAR Craftsman Truck Series Race For Toyota (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 08-01-2004 11:30 AM |
