| Junior Member Join Date: Nov 2006
| code 41 TPS help! Ok, I have an 88 toyota pickup with a 6 cyl. It pulsates on idle and doesnt want to rev. I got a code 41 which is the TPS but I tested the TPS and its within limits. I even swapped it out for another one but that one did the same thing. When running I can take off teh TPS wire and it'll rev fine but it idles real high. Its somehting to do with the TPS circut but it isnt the TPS... Any body ever have this happen? All vaccum lines seem to be hooked up, wires connected etc. |
| Full Member Join Date: Nov 2006 Location: NJ
| try resetting teh computer |
| Way past that... even tried a replacement computer... new airflow sensor,,, think its the nock sensor, will let you know.. |
| i done the same thing with mine. i replaced mine and it started to run right about half the time. if you take some spray cleaner and blow evwerything off around the throttle body, meaning all the carbon buildup, it should go back to functioning right. |
| location of keypad code??? | gvmotors | Introductions | 1 | 08-25-2006 11:04 AM |
| Code 42-Chevy 1500 | rockitman | Chevy Truck Forum | 1 | 06-01-2006 07:30 PM |
| code 43 nightmare | Deltadog | Chevy Truck Forum | 1 | 05-30-2006 03:37 AM |
| Code 54 | Slo 1 | Chevy Truck Forum | 3 | 11-24-2005 12:17 PM |
| Foes: Enforcing ORV code could be impossible (Hi-Desert Star) | trucknews | Truck News (headlines) | 0 | 07-27-2005 01:30 AM |
