| Full Member Join Date: Sep 2006
| Miss or hesitation? I have a miss or something in my 93 pick up. I had just did a engine swap, run fine with only a slight hesitation at the begining of the rpm range, as the rpms gotr higher it picked up. Now it seems to be getting worse. Here is what I have as miss or hesitation. It seems to come and go, not consistant at all. While driving it will be fine and then out of the blue it will start, then it will go away, then come back. It seems to have started after it has been a little colder out, might be a coincidence. It does it any speed other than a the very begining of the throttle and full throttle. If I give it full throttle it accerates great, if I leave off full throttle the slightest bit it misses or hesitates and accutally slows down. Sometimes when I come to a stop it idles really rough like it's missing or something. Timing is good and it has a brand new timing set installed by a ace mechanic, before I installed the engine. My average gas milage has been around 16 - 17 in town with a 24 mpg on a 240 mile highway trip ( that was before this started). My check engine light was on from the start after I installed the ingine. I had installed the jumper wire to check for engine codes and got a 21 (o2 sensor). I did not get any other codes. Would a bad o2 sensor be causing this problem? The only thing I did not put new on the engine was cap & rotor and plug wires because they looked fairly new and in good shape. Any ideas or info would be helpful, I'm hoping it's something simple. |
| | #2 | |
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed | |
| | #3 | |
| Senior Member Join Date: May 2006
ignition? injectors? eh **** it im sorry man i cant help you, i just felt like posting something | |
| I had a suggestion from another forum. he had the same symptoms i had and he unpluged the tps. So I tried it and the truck is running the best it has ever. So I guess I need to have the tps adjusted or a new one. |
| | #5 | |
| 2002 chevy hesitation | mario.adame | Introductions | 1 | 09-29-2006 07:49 AM |
| Need help with hesitation with my 2000 Chevy Silverado | RSailer | Chevy Truck Forum | 7 | 05-08-2006 06:19 PM |
| bad miss in a 3.0 v6 Nissan | srw45 | Nissan Truck Forum | 0 | 12-11-2005 08:21 AM |
| 07/26/05 - Lufkin Boy Swerves To Miss Truck, Hits Woman Instead (KTRE-TV East Texas) | trucknews | Truck News (headlines) | 0 | 07-26-2005 03:30 PM |
| 2006 Ridgeline, a can’t miss truck from Honda (Whittier Daily news) | trucknews | Truck News (headlines) | 1 | 07-06-2005 11:49 AM |
