Go Back   Truck Forum > Truck Classifieds
Reply Truck Classifieds - List your truck, parts & other items for sale.
Old 08-04-2008, 01:48 PM   #11
junior3382's Avatar
Location: Currently, I live in Lancaster country, Pennsylvania.
well thats just it, they ARE out there for the 2 door, but not the 4-door for this reason alone....
Lets get some mud on the tires...eh?!?!?
OWN:
1998 Chevy Blazer ls 4x4
4.3l Vortec V6
1998 Mazda B3000 SE 4WD
3.0L V6
3" lift
31x10.50 Liberator A/T's
Old 08-04-2008, 01:50 PM   #12
Banned
looks like i got some fiberglass work to do then. the wheel arches are the same right
Old 08-04-2008, 01:52 PM   #13
Banned
wow 2 pages in undr an hour lol hot thread
Old 08-04-2008, 01:56 PM   #14
junior3382's Avatar
HEHEHE I know, I get passionate about this subject... and you know if you are able to do the fiberglass work right, then yeah it may work... and would definitely be different. I think the wheel wells are the same between the 2 and 4 doors, but even if not, you plan to cut and fit anyways..... And if it works and looks as hot as I imagine, I may drive up your way and we could do mine the same as well! LOL....
OWN:
4.3l Vortec V6
3.0L V6
3" lift
Old 08-04-2008, 02:07 PM   #15
Banned
i have alot of fiberglass experiance. i build alot of sub enclosures for a buddy of mine. but i must run out so ill talk to you later about it some more.
Old 08-04-2008, 02:09 PM   #16
junior3382's Avatar
cool, sounds like I am comming up there for speaker boxes as well as fender flares...LOL..... Alright, check you later bud....
OWN:
4.3l Vortec V6
3.0L V6
3" lift
Old 09-06-2008, 04:39 PM   #17
2000 envoy is on a distinguished road
the zr2 gets it lift from the frame itself not the suspension. if ur lookin for lift just go after market
2000 envoy is offline   Reply With Quote
Old 09-06-2008, 07:00 PM   #18
junior3382's Avatar
This was posted on another forum recently that will more then answer the question in the actuall differences between the 4x4 and Zr2 suspensions in the GM S-class trucks. It is more then just one thing. I thought this was helpful, and it may help someone else too.
The following factory-installed features are what made the ZR2 standout from other 4x4 trucks offered in the S-Series class.
  • Ladder Type Frame with Modified Mounting Points
  • 100mm wider track (3.9 inches wider than regular S-10)
  • Increased Ground Clearance (Approx 3" over Regular S-Series 4x4)
  • Enhanced front (7.25" ring gear) and rear (8.5" ring gear) axles w/ 3.73:1 rear-axle ratio
  • Larger wheel and axle bearings
  • 31 x 10.50" BFG A/T Tires (Pickup), 31 x 10.50" BFG Longtrails (Blazer)
  • Fender Flares
    • Spectra Gray on the Chevrolet Models, despite body color. Body color on all GMC Models.
  • 46mm gas pressurized Bilstein Monotube shocks
  • Rear Track Bar (Pickup), Front Anti-Sway Bar (Blazer)
  • Skid Plates
  • Front/Rear Disc brakes (1998-2005) , Disc/Drum brakes (1994-1997)
  • Full Size Spare Tire
OWN:
4.3l Vortec V6
3.0L V6
3" lift
Old 09-06-2008, 07:02 PM   #19
junior3382's Avatar
Except for the last one... all s-series trucks had full size spares... sorry... but wanted to keep the quote complete.
OWN:
4.3l Vortec V6
3.0L V6
3" lift
Old 09-07-2008, 12:15 PM   #20
Banned
i didnt relize they were that different till i acually looked under one and saw it. basically nothing would work lol. but im gonna let her be till winter for now. untill she breaks down again. i am still getting that stupid trans componant slipping code. its p1870 i believe. it only does it when i drive the truck so i think it has something to do with me. but then i am the only one that takes it on any kind of long trip. the wife mostly drives it from home to work. and thats onyl like 4 miles a day. who knows.
3/4 ton suspension 01pewtergmc GMC Truck Forum 4 04-12-2008 08:41 PM
What is the Z71 suspension??? some more ???'s usmceric1 Chevy Truck Forum 6 09-25-2007 06:15 PM
Stiffer Suspension will4831 GMC Truck Forum 10 08-21-2006 10:56 PM
suspension lift 88chev GMC Truck Forum 5 07-31-2006 10:36 PM
